How do you rough adjust vertically the red tube on a G70?
EricO
Posted: Thu Feb 04, 2010 11:18 pm    Post subject: How do you rough adjust vertically the red tube on a G70?
I've just ceiling mounted my Sony G70 after moving to a new house and my red tube is WAY off. Too far off to adjust by the controls. How do I adjust the tube vertically? Left to right is no problem but I can't seem to find a way to move the tube up.
Posted: Thu Feb 04, 2010 11:20 pm    Post subject:
The center zone, the center square. I usually set all H and V adjustments to 128, then correct the tubes to suit, but try and use as little as possible.
It's normal for the V shift on one or more tubes to be down to say 110 and up to say 160, no worries there.
EricO
Posted: Thu Feb 04, 2010 11:28 pm    Post subject: Not enough adjustment available
I take it to max and it's still way short of matching up. Is there a way to move the tube up and down as there is to move it left to right by loosening screws and manually adjusting?
Posted: Thu Feb 04, 2010 11:36 pm    Post subject:
No, wrong adjustment on your part. You need to press the 'zone' button, which is the coarse V adjustment whereas the R and B shift buttons on the remote are the fine adjustments.
EricO
Posted: Thu Feb 04, 2010 11:42 pm    Post subject:
You are my projector God! Thumbs Up That did the trick. I had it dialed in nice at the old house, but I did that 3 yrs ago and forgot everything. Thanks again! I'll try to put pics up of my theater room when I'm somewhat finished, which should be in a couple weeks. Maybe I'll be able to figure out that Harmony control I got from you by then too! lol
