marquee 8000
dmarnold
Posted: Sat Jan 30, 2010 5:23 am    Post subject: marquee 8000
curt,
got any HVPS for an 8000? Got any 8500 chassis' with bad/burnt tubes?
enjoy today, for change is on the way
dmarnold
Posted: Wed Feb 03, 2010 2:31 am    Post subject:
aw sheet, ain't there no way to check the HVPS out of the unit?
Posted: Wed Feb 03, 2010 2:38 am    Post subject:
No, you need another PJ to check.
dmarnold
Posted: Wed Feb 03, 2010 2:54 am    Post subject:
one other note: when i push the power button pn rear panel, fan in center rear visibly shunts, then does not move. No hv anywhere as far as i can tell
edited to note: it was late ..... i was tired ..... and i meant to post this in the "FREEBIE" thread.....
Posted: Wed Feb 03, 2010 3:23 am    Post subject:
What do you mean power button on rear Panel? There is no power button on the rear panel. Just either the connected remote or the IR remote.
There are three belly fans in the center of the PJ under the Tubes you might be able to see them spin if you look down into the HDM or FCM heat sink holes in their cages.
If one is not working it might not be the HVPS but a cooked HDM.
dmarnold
Posted: Wed Feb 03, 2010 3:38 am    Post subject:
no, beg to differ but there's a button on rear panel for power and after pushing on the main power button of front of pj, which puts in stand-by mode, i then press the power button( farthest left on rear) and see the rear center top fan shunt slightly then into previously mentioned cycle it goes
dmarnold
Posted: Wed Feb 03, 2010 3:39 am    Post subject:
no fans run as far as i can tell.............
dmarnold
Posted: Wed Feb 03, 2010 3:45 am    Post subject:
sheeeeeetttt!
my bad, i'm babblin' on about my runco not my Marquee!
bed time obviously!
