What's the RS232 (DB9) connection to the Barco 909?
Posted: Fri Jan 29, 2010 1:56 pm    Post subject: What's the RS232 (DB9) connection to the Barco 909?
Is it straight pin for pin, or swapped pin 2 to 3.
It's been awhile since I've had to do a DB9 hookup to a Barco 909 and I've also upgraded my laptop. So I'm starting out new, not knowing if there's a problem with the Laptop or the connection.
I know how to use the software, just need to get it to communicate.
Posted: Fri Jan 29, 2010 10:56 pm    Post subject:
Mike, I don't think you will do any harm. Try it one way. If it doesn't work then try the other.
Is there a setting in the projectors menu to activate the port? How are you connecting to the laptop?
You may have to make all the connections first then re-boot the PC.
Posted: Fri Jan 29, 2010 11:18 pm    Post subject:
Thanks Chip.. Very Happy
It's a direct connect. I now have it working. I had to select the address that the projectors were programed to in the software in order for it to connect. T^he default was zero (0), but the projector was programmed to three (3).
Getting older confuses things, or I forget things as a result of getting older..Very Happy
Posted: Fri Jan 29, 2010 11:25 pm    Post subject:
PM sent but it looks like it's not needed... Wink
