dmarnold
Joined: 18 Jan 2010 Posts: 73 Location: St. Louis, MO
| Posted: Mon Jan 18, 2010 6:04 am Post subject: ...... li'l help please.... |
hello everyone,
been so long i couldn't remember my password
i need a little help
my ECP 3100 is displaying two distinct halves directly divided in the center of the screen, left side being brighter than right
did i hit a wrong button to bring about this split screen?
_________________ enjoy today, for change is on the way
| Posted: Mon Jan 18, 2010 6:22 am Post subject: |
Do the test patterns do it too. (oops, 1 test pattern:)
THere is a modification for this I believe, not sure if it's documented here though. It should be in the archives in the avsforum though.
dmarnold
| Posted: Mon Jan 18, 2010 6:32 am Post subject: |
Hello Curt,
I seem to remember seeing something regarding "split screen" in my service manual but can't find the reference as yet
i'll keep searching tomorrow
it's late
LOTREE
Joined: 19 Mar 2006 Posts: 401 Location: Paradise, Newfoundland
dmarnold
| Posted: Sun Jan 24, 2010 7:11 am Post subject: |
i still seem to remember doing something in the past that brought this "split screen" look into effect before, and was able to turn it off. no luck this time yet.....
LOTREE
| Posted: Sun Jan 24, 2010 6:16 pm Post subject: |
Turn up the contrast perhaps? Or adjust pots R1 and R5 on the waveform generator board.
_________________ Zenith Pro 1200x | Electrohome ECP 4500 | Yamaha HTR-5740 | HTPC & Speaker build to follow
dmarnold
| Posted: Sat Jan 30, 2010 7:05 am Post subject: breakthrough |
pulled NEC scan converter out of line, replaced with runco branded converter that's exactly the same, problem solved. might have been a bad bnc cable connection, will swap them back tomorrow to check.
night all!
LOTREE
| Posted: Sat Jan 30, 2010 3:52 pm Post subject: |
Good to hear you solved it
Interesting tidbit about this fix though. My 4500 will only display the 1/2 bright image when no source is on, otherwise I see this and my card isn't modded:
dmarnold
| Posted: Sun Jan 31, 2010 7:01 pm Post subject: update |
reinstallled NEC SC and vertical split with light/dark halves back. swithced bact to runco sc, split gone.
