extron rgb118 plus questions
stormwind13
Posted: Mon Jan 11, 2010 8:10 pm    Post subject: extron rgb118 plus questions
i recently bought a barco 801 graphics projector- and i was told i needed this box to interface a pc with it.
so i also bought an extron rgb118 plus interface to work with it. Upon going to hook this unit up, i noticed the cable was not standard vga- it is a db-9 connector. do i just need a vga-db9 converter?
stormwind13
Posted: Mon Jan 11, 2010 8:15 pm    Post subject:
also, i have a vga to component video cable adapter- if i were to buy 3 rca to bnc adapters would this work instead?
stormwind13
Posted: Tue Jan 12, 2010 12:54 am    Post subject:
anyone?
Posted: Tue Jan 12, 2010 1:20 am    Post subject:
Hello
That is no help, I have VGA to 9pin cables here made for Extron interfaces for $40 and postage, 18", 36" and 48"
RaWsHaRk
Posted: Tue Jan 12, 2010 1:52 pm    Post subject:
I think You can buy a normal vga->5 bnc cable and hook Your computer to bnc, you dont need that extron unless you want to use 2 ports for the projector. where are you located, i have one extra extron box and cables that came with a data 801s to me.
Electrohome Marquee 7500.
stormwind13
Posted: Wed Jan 13, 2010 4:19 am    Post subject:
i live in minnesota.
Posted: Wed Jan 13, 2010 6:35 am    Post subject:
Get one of these cables and try 1024x768 directly from your PC.
http://www.amazon.com/HD-15-Video-Cable-Monitor-cable/dp/B001UJMGZC/ref=sr_1_25?ie=UTF8&s=electronics&qid=1263364259&sr=8-25&tag=curtpalmecrtp-20
Then get Powerstrip and set all you sync's to negative negative - - for other resolution like 1080i. Or take Tim up on his offer for one of the VGA HD15 to 9 pin Extron cables and run your PC to that then from the extron to your projector and set your Extron to force negative sync.
If you end up getting the cable from Tim you'll also need a cable to run from the PC to the Extron box:
DVI-I to VGA HD15 male
http://www.amazon.com/Cables-Go-27591-Female-Extension/dp/B0002GUL88/ref=sr_1_42?ie=UTF8&s=electronics&qid=1263364579&sr=1-42&tag=curtpalmecrtp-20
Or if your PC is good old HD15 VGA output VGA to VGA:
http://www.amazon.com/Cables-Go-28012-Monitor-Ferrites/dp/B0002J28NQ/ref=sr_1_8?ie=UTF8&s=electronics&qid=1263364551&sr=1-8&tag=curtpalmecrtp-20
stormwind13
Posted: Thu Jan 14, 2010 6:20 pm    Post subject:
is powerstrip some sort of software interface?
Posted: Fri Jan 15, 2010 12:25 am    Post subject:
Whoops, meant to include the link: http://entechtaiwan.com/util/ps.shtm
Yes it's video control software to set up custom resolutions.
