Setting custom resolution with Nvidia and Powestrip
Posted: Sun Jan 10, 2010 2:40 am    Post subject: Setting custom resolution with Nvidia and Powestrip
Here's a one stop shop for this instead of having it spread out through many threads.
If you find a tid bit feel free to copy/paste it here. Even if it isn't yours.
Just remember to give credit for the post and a link to the original post if it's copied.
Mark had a great one tonight so I'm doing the copy/paste:
http://www.curtpalme.com/forum/viewtopic.php?p=228983#228983
__________________________________________________________________________________________________
Club Member
Link Posted: Sat Jan 09, 2010 7:35 pm Post subject:
I dunno, I've never used anything but a PC.
But did you know, that with the Nvidia timings your have to use "half" the vertical res if you're doing interlaced - so 540 instead of 1080....boy that cost me some hours...
___________________________________________________________________________________________________
Posted: Mon Jan 11, 2010 8:39 am    Post subject:
Here are working timings for 1080i 71.929hz on Nvidia (change the timing from Auto to create or tweak it..).
Notice the GDI timing is 72hz? This means software like XBMC "sees" the right refresh rate, which it won't with Powerstrip on an ATi.
 Filesize:  127.33 KB
 Viewed:  20213 Time(s)
Posted: Mon Jan 11, 2010 8:45 am    Post subject:
Oh, and Jeremy, you could transpose the contents of that other thread with the Ati details here (and delete this post).
GREG1292
Posted: Thu Jan 14, 2010 5:00 pm    Post subject: Re: Setting custom resolution with Nvidia and Powestrip
Club Member
So that is why my projector freaks out on 1080I Shocked Cost me some hours as well Analog! Thumbs Up
Mark is that with just bnc or you have an hdfury or moome stripper as well! These timings I assume won't
stress out the electronics?
Great idea for a thread Analog
the_maniac
Posted: Fri Jan 29, 2010 9:00 am    Post subject:
on the pic above the interlaced check box is disabled, so when you set the lines to 540 is it enabled ?
or is it working with powerstrip even when the check box is disabled ?
i think i'm going to change my mainboard from ATI onboard to Nvidia onboard (8200) because of gamma correction but only if im 100% sure that 1080i works
www.diy-community.de
Posted: Fri Jan 29, 2010 9:49 am    Post subject:
"on the pic above the interlaced check box is disabled, so when you set the lines to 540 is it enabled ? "
It works when you set Timing Standard to custom - all the boxes become active.
"or is it working with powerstrip even when the check box is disabled ? "
Do not use Powerstrip with an Nvidia card.
And yes, 1080i works on Nvidia. At least it does on my 8500 card.
johnnynickel
Posted: Mon Jan 10, 2011 8:23 pm    Post subject:
Why shouldn't you use powerstrip with nvidia?
johnnynickel
Posted: Mon Jan 10, 2011 8:35 pm    Post subject:
the answer is right in that link. sorry.
