Help with Moome XG-FULLHD
mgould
TV/Projector: NEC XG-110
Posted: Fri Jan 08, 2010 3:35 pm    Post subject: Help with Moome XG-FULLHD
Hello all,
Hope everyone had a wonderful holiday season.
I Installed my Moome and got the 720p and 1080I resolutions working ok. Focusing is a bit off. Not bad but a bit off. I have to move the electronic focus way to far. Need to get Terry F. to look at that for me. But that is not what this is about.
When I set up 1080P the image was shifted left about 4 inches. Seems the whole raster may shift, not sure however. I have no scaler just running HDMI from a BD-P3600 directly into the Moome. Not sure how to go about fixing this. I’m sure others here have had the issue but when I search I find most of them had scalers.
I would appreciate any help you all can offer.
Mark
moome
Posted: Fri Jan 08, 2010 3:48 pm    Post subject:
did you use the position function on XG to shift the image?
I use on my XG135 and image is centered~
mgould
Posted: Fri Jan 08, 2010 4:23 pm    Post subject:
Yes I did. Did not seem to work but I will look at it again tonight when I get home and let you know exactly what I am seeing.
I will reply again later.
mark
jarseneau
Posted: Fri Jan 08, 2010 4:47 pm    Post subject:
There doesn't appear to be any way to avoid wrap around on the XG at 1080p without the use of either a video processor or a PC. This isn't caused by the moome card, it's just that you start to use 1080p capable sources along with the HDMI use. What the VP or PC give you is a way to adjust the front porch timing to allow the image to fit in the raster without wraparound.
Jerry
mgould
Posted: Sat Jan 09, 2010 8:47 pm    Post subject:
Ok Moome was correct. I got the image centered with no wrap around at all. I do get a weird banding like motioning horizontally in the image. The bands tend to move with the scene. However they are not seen won a pure white test pattern nor are the noticeable on the Samsung splash page. Only visible in movie.
Any Ideas?
Mark
moome
Posted: Tue Jan 12, 2010 4:54 am    Post subject:
is the banding at edge of imge, you can use blanking function to blank it~
mgould
Posted: Tue Jan 12, 2010 5:43 am    Post subject:
No. That looks fine. Let me try to describe.
Center of a scene......
Arnold is looking at Stone. All looks good until Arnold moves. Then there is a streak from Arnolds face to the right hand of the screen horizontally.
If you have seen point banding on a white field translate that to a moving image on the screen. Seems to be happening between high contrast differences in the image.
Hard to explain but this is not wrap around or point convergence banding. Also only happens in 1080p
sdubreuil
Posted: Sun Jan 22, 2012 4:14 pm    Post subject:
I have the same issue with XG-Fullhd. I did not know that we call this banding. And yes its happening only on 1080p.
Were you able to fix the issue?
Thnaks
Stephane
electriceye
Posted: Tue Feb 14, 2012 11:04 pm    Post subject:
I have the same problem with "banding" and "foldover" with my XG w/Moome hdmi card at 1080p. I've searched the posts here and it seems you need a video processor to adjust some porch settings. I've been trying to figure out which processor and what timings will work with an XG135, but haven't come up with anything. Anyone have any suggestions?
It's an ill wind that doesn't dry someone's clothes
