Looking for solution connecting PT-AX100E with PS3 over 15m
Jacko
Posted: Fri Jan 08, 2010 8:59 am    Post subject: Looking for solution connecting PT-AX100E with PS3 over 15m
Hello everybody,
sorry if the question is repeated.
I got a little challenge (not saying problems) connecting projector Panasonic PT-AX100E (HDCP compliant) with a PS3/SAT-Receiver.
When using 12m long HDMI cable I get following problems:
- with SAT-receiver: HDCP Problem when using 12m long HDMI cable, blinking screen when using 1m long cable
- with PS3: screen blinking from time to time
I checked three different cables (including short ones: 0.5m), shut down the devices few times with no success.
I have the possibility to use DVI instead of HDMI on my SAT-receiver and then everything works fine. However, I do not have such possibility with PS3.
I want to connect the projector with the devices for a distance of about 15m (600inches). According to HDFury specification, maximal 50inches long cables are supported. Can HDFury help me in that case or I need different solution?
Can anyone help me? Does it seem that my projector is damaged?
Best regards,
Jacko
