Calibrate with Local Dimming On or Off?
bama29
Posted: Mon Dec 28, 2009 4:33 pm    Post subject: Calibrate with Local Dimming On or Off?
I am looking for some input from those that might have experience calibrating a local dimming television set.
I have a Toshiba 55SV670U LED Backlit LCD set with Local Dimming, which I am attempting to calibrate. I have the Enhanced Chroma 5 probe and Calman Home software.
Should calibration be done with Local Dimming (LD) enabled or disabled? I know the light output is reduced when LD is enabled.
Also Toshiba has a anti-blur technology called "Clearscan240" that inserts black frames in between normal frames. This also seems to reduce light output. Should this be disabled when Calibrating?
Thanks in advance.
Michael
