dyates69
| Posted: Mon Dec 07, 2009 2:42 pm Post subject: What tubes will go in a BG808? |
Will NEC XG tubes (P16) go into an 808? Are P16's all the same, or does the whole part number need to be taken into account?
Thanks.
| Posted: Mon Dec 07, 2009 2:51 pm Post subject: |
No, only the 180DVBs will, and the 180DMBs can as well with a small modification.
If you have a minty set of NEC XG tubes that you want to trade for a set of tubes for the BArco, give me a shout.
| Posted: Mon Dec 07, 2009 7:38 pm Post subject: |
If i'm not mistaken,there's a set of P16LNN's or LNQ's? that will go into the marquee's and Barco's, however the XG + G70 P16's are much shorter tubes.
Elaine Benes
| Posted: Mon Dec 07, 2009 11:31 pm Post subject: |
Don't forget the high res versions of the 180DVB, there's the PT18-205, and I think an even later one with a different part number as well...all are the same large neck tubes and can even be used mixed in the same projector if need be.
| Posted: Mon Dec 07, 2009 11:45 pm Post subject: |
Dat be true!
| Posted: Tue Dec 08, 2009 2:04 am Post subject: |
| draganm wrote: | | If i'm not mistaken,there's a set of P16LNN's or LNQ's? that will go into the marquee's and Barco's, however the XG + G70 P16's are much shorter tubes. |
The neck is thinner. So the magnetics are closer to the beam.
However, on the Xtra, the blue and red are shorter (and harder to come by).
secstate
| Posted: Tue Dec 08, 2009 2:35 am Post subject: |
The P16LNPs and P16LNQs will both work and are high res along with the PT18-205s. There are later P16s that will also work but I don't recall the numbers. These are all drop in replacements (assuming the right physical hardware on the tube) for 180DVBs.
dyates69
| Posted: Wed Dec 09, 2009 11:28 am Post subject: |
Okay thanks guys.
robin36mac
| Posted: Wed Dec 09, 2009 6:55 pm Post subject: |
I profit of this thread to ask : I have a set of P16LXW in my BG808 (180DVB changed by previous owner), and I have no idea from wich model they come originaly... Do you know ? Cine8, 908 ? I don't think so, tubes are not LC's...
Thanks !
Person99
| Posted: Wed Dec 09, 2009 8:58 pm Post subject: |
| robin36mac wrote: | Hi,
Thanks ! |
The Cine 8, Cine 8 Onyx, and Zenith Pro 1200x used those IIRC
_________________ Dave
