| Posted: Sat Dec 05, 2009 4:56 am Post subject: Marquee longbow issue, vertical bars.Scott Any Ideas?Solved |
Hi Guys, and asking the Marquee techs here. have you ever seen what is in the Pics below before?
I originally thought it was the Issue of the TV-one blenders but Now I think its inherent in the longbows.
I took the Tv-One out of the system and put into the second Moome HDMI slot my Lumagen HDQ
and the set up I had with my old M8500 1080p@48. So i put up a full field white and lower contrast so i don't burn my eyes out and so the lines can be photographed easier.
Also I noticed the internal menu's streak while looking but it was only the menus so no big deal,
as I think All marquees do this , and its only noticeable looking into the tube at low contrast.
So I thought it might be the new moome card and I put the old back in but it was the same.
I did not change out to a new Vim yet, i am to tired to do it now but will tomorrow afternoon.
EDIT: You can also see it here where i was sending this info to the Tv-One guys that the red and blue colr fields do not blend correctly in YUV mode. But thats another story: here is the bars on either side of the purple bar.
So what is it? And what can cause it? Could it be the peaking circuit on the vim?( tried non peaking circuit Vim not it)
I have never noticed this on any other Marquee I have.
More testing will happen tomorrow.
But if Scott is lurking the forums tonight chime in please
antorsae
| Posted: Sat Dec 05, 2009 7:13 am Post subject: |
Nash - Do a full geometry reset and see if it's still there. It may be vertical banding.
| Posted: Sat Dec 05, 2009 1:54 pm Post subject: |
| antorsae wrote: | | Nash - Do a full geometry reset and see if it's still there. It may be vertical banding. |
I never heard of A marquee vertical banding? So i need to to initialize the PJ put up the field and see if its there?
I set up a new memory block for the lumagen starting from scratch and its there. I don't think thats it but I'll try again.
Do you think just a new memory block start or the whole initialization is needed?
| Posted: Sat Dec 05, 2009 4:50 pm Post subject: |
Have you set the blanking? Make sure your blanking is right up to the boarder of the image. I have seen similar distortion to this when the blanking is not in use.
Can you see the distortion on screen or only looking into the tubes?
| Posted: Sat Dec 05, 2009 6:15 pm Post subject: |
| CIR Engineering wrote: | Have you set the blanking? Make sure your blanking is right up to the boarder of the image. I have seen similar distortion to this when the blanking is not in use.
craigr |
I'm using no blanking. I'll try it when i get home later .
| Posted: Sat Dec 05, 2009 6:34 pm Post subject: |
there's a TCB for jail-bar's and menu streaking, I would think your 8503 VIM would have it though?
| Posted: Sat Dec 05, 2009 7:38 pm Post subject: |
| draganm wrote: | | there's a TCB for jail-bar's and menu streaking, I would think your 8503 VIM would have it though? |
Exactly, when i got the PJ's, as you remember, I took all the boards out of the one and looked them over and posted pics.
All boards have every tech bulletin done to them.
Maybe this issue will be another tech bulletin in the making.
antorsae
| Posted: Sat Dec 05, 2009 7:53 pm Post subject: |
| Nashou66 wrote: | | antorsae wrote: | | Nash - Do a full geometry reset and see if it's still there. It may be vertical banding. |
Athanasios |
Once I forced green convergence way to much while playing with it vertically and I got the equivalent to vertical banding. A new memory block (recall) with everything zero'd in in that one would do.
antorsae
| Posted: Sat Dec 05, 2009 7:58 pm Post subject: |
Nash - on the TV-One pic the bars are symmetric... that's too strange. Can you feed just one projector with a different source?
| Posted: Sat Dec 05, 2009 8:04 pm Post subject: |
| antorsae wrote: | | Nash - on the TV-One pic the bars are symmetric... that's too strange. Can you feed just one projector with a different source? |
The color solid pics are from my Lumagen HDQ. Running 1080p@48 RGB input 4:4:4 from my LG BH100.
The bars are in exactly the same place as were in the TV-One units. I did a side by side comparison with a full field, and actually the solid colors are not from the bH 100, its from the lumagens internal patters and i had my Bh 200 on the TV-Ones
using a full field from the AVCHD disc.
I am Cashing out the register now and finishing work, so i'll be home soon to try before I have a family function to go to.
| Posted: Sat Dec 05, 2009 10:21 pm Post subject: |
Ok I tried a new Recall and cleared it out and left it as is , no convergence or anything else touched.
The lines were still there.
So i went to my other Long bow and pulled the vim since i only have the Moome card and not any RGBHV's as the other PJ does, easier to dismantle . I put in another 02P vim with no peaking circuit and its still there.
Also Scott if you read this remember i told you about those horizontal bands of vertical distortion lines and I could not capture it? well this other vim shows it better, But i made it less noticeable by pushing on the slot 2 side of the vim connector against the back plane. It was reduced but still there. Pics of vertical bars with different Vim and
the horizontal bands of vertical distortion
Bars and distortion if you look closely
Close up of distortions, these have always been here since I got the longbows.
Scott do you think it could be the Longbow mods? And could I try a non Ultra HDM here to see if its that?
So now I have two issue with the PJ's and one with the Tv_ones.
| Posted: Sat Dec 05, 2009 11:21 pm Post subject: |
Hello
Try unplugging the stig and convergence yokes. Try running green without the vIM coax. Try scoping output of VIM coax, use horizontal rate on the scope. Try also another HDM, earlier HDMs are OK to try. Try another control board, OK to try earlier versions.
tse
| Posted: Sun Dec 06, 2009 1:31 am Post subject: |
The video input is with the options slot? Try removing the option card and connect some video to the main RGB inputs to see if it is still there. Try removing all input video and look at the internal test patterns at internal test frequencies close to your external ones.
Scott
Thomas Jefferson
| Posted: Sun Dec 06, 2009 3:55 am Post subject: |
Thanks Tim And Scott,
First the vertical bars, they are there with no video input connected and with internal video, and new CLM. As you lower contrast they become
much more visible and go across the entire tube face on all colors.
Also the vertical lines in the horizontal bands are still there as well.
So i decided to remove the Astig and CVA cables, the Vertical bars are still there but the Vertical lines in the horizontal bars are gone.
so the SAB is casing the vertical lines in the horizontal bands.
But the bigger more noticeable problem remains.
I still need to swap out the HDM, will do that now, i need to find my 08 HDM with the Wimas I think its an Ultra board.
Edit: 11:16pm:
Ok Swapped out the HDM and the Bars are still there on all tubes, both PJ's. ?????
I also disconnected one channel of the focus board, red still there. So it could be the VNB's or the CCM, the CCm is next.
be back soon...
Edit: 11:31pm
Pulled the CCM and no change. Bars still there.
So now what do I do for the horizontal bands with the vertical lines in them, any part Scott that might be the culprit?
| Posted: Sun Dec 06, 2009 9:46 pm Post subject: |
| Tim in Phoenix wrote: | Hello
Hi Tim, so do you mean try to get the tube lit up with out the green coax connected? How can i do that, i tied by removing the mini rca from the vim and turning on the set, obviously no image, so i raised the brightness to try to get the rater to light up but it did nothing.
Also what should I be looking for while scoping the Mini coax? and what pattern should I use, just a full field internal
be ok?
| Posted: Sun Dec 06, 2009 10:16 pm Post subject: |
| Nashou66 wrote: | | Tim in Phoenix wrote: | Hello
be ok?
Athanasios |
I wonder if he's thinking something that crossed my mind. I kinda discarded it since it was to WAG. Could it be imperfection in the phospher coating. I discarded the thought because whats the chance of it being in all the tubes. I still dont think so but hey, whats the harm in checking.
You would have to turn the G2 up high for bright raster then pull the video coax. It should stay lit.
| Posted: Sun Dec 06, 2009 10:29 pm Post subject: |
I was thinking that too Ron, bad phosphor but on both Longbows? The I thought bad power so i ran it from a different plug. same thing.
To I could try the G2 raised but its hard to see it if the tube is too bright, its best seen at lower contrast levels but noticeable on the Screen at
normal viewing levels. I was almost tempted to use my extended VNB cables and put the new VDC red LUG i have with all the magnetics on it. But too lazy at the moment.
Plus id have to make a tall table to get the spare tube right up to the PJ since its on the ceiling now. I think a VNB swap should be next.
But i'll try the G2 not sure how to pull the coax off the VNB. I'll raise the G2 on one of the colors save the new setting and then pull the coax and start it up again.
Any harm doing it that way or wont it work?
Also what would cause those vertical squiggles in the horizontal bands in the zoomed pic above from the astig board? that is not fed into the video signal but just controls the electron beam in the focus coil. Looks like digital noise from the control might be getting into the video somehow through the power rails?
Still Waiting for Scott to explain that one.
I'll wait for the G2 answer., I could pull the coax from the VNB but if you know how its connected there it doesnt just pull off and I am not going to try to hold the VNB steady with a HV DC G2 line and even the 85 DC rail too Ouch!!!
MikeEby
| Posted: Sun Dec 06, 2009 10:44 pm Post subject: |
When you shift horiz do the bars move? Maybe you posted that already, I didn't see it....If they do, I would think its not the phosphor or the tube.
| Posted: Sun Dec 06, 2009 11:00 pm Post subject: |
| MikeEby wrote: | When you shift horiz do the bars move? Maybe you posted that already, I didn't see it....If they do its I would think its not the phosphor or the tube.
Mike |
Good Idea Mike, I am using the internal patters and Phase had no effect but size did, the bars move with size.
they get thinner as I shrink and get wider as I expand the size. it almost does sound like a banding issue
that Antorsea mentioned but I put all linearity controls to default(50) an zeroed out the convergence in the menu
by pressing 0 while in the menu and i could see the convergence jump to default.
Also I see some diagonal noise like you get when G2 s set to high, but only when I lower the contrast, the amount of noise( sparkles) on the internal full field pattern is crazy! As you lower the contrast it is much much more noticeable.
the contrast i have been looking at this problem with is at about 20, very low where a full white field is barely noticeable on screen, and my eyes are still hurting after each session i need to go get my sun glasses.
EDIT. these are 2004 builds and just put in service this year by me. So i should probably clean all contacts through out the set. I pulled the VDM cables off and on the pins a few times to clean any possible oxidation but nothing. A different CLM had no change so cleaning all the chips probably wont make a difference.
Strange indeed.
| Posted: Sun Dec 06, 2009 11:03 pm Post subject: |
Mike |
This is true. Thats a good test.
