karmat63
| Posted: Sat Nov 28, 2009 7:45 pm Post subject: Which one would you prefer.. |
Which would be the best solution among these two:
Bd player (1080p24) > Mux HD (DVI) > Lumagen HDP (RGBHV) > marquee 9500
or
Bd player (1080p24) > Lumagen HDP (DVI/HDMI) > Moome VIM fullHd V3 > marquee 9500
In both solution you have HDCP stripping and gamma boost (in the first one using Lumagen's parametric gamma correction).
Which one do you think would be the smartest one (apart from economic consideration)?
karmat63
| Posted: Sun Nov 29, 2009 3:31 pm Post subject: |
Any opinion?
MikeEby
| Posted: Sun Nov 29, 2009 5:00 pm Post subject: |
I have no experience with either, I agree with Athansios. Other reason would be because the Gamma boost on the lumagen is in the digital domain...When on the Moome I believe its analog and less precise
Question though...
Where is you're audio processor? 1/2 the fun of Blu-ray is great HD audio...A must have in my book.
karmat63
| Posted: Sun Nov 29, 2009 8:26 pm Post subject: |
| Nashou66 wrote: | the second one. no MUX-HD one reason is the lumagen does excellent 3:2 pull down to output 1080p@60 via HDMI, but i ran it at 48hz and it looked great too, and for scope i used 800p@72 using the shrink function in the lumagen menu, or a resistor mod on the VDM of the marquee. Either way works.
Athansios |
Yes, but Lumagen is, in both options, in the video chain; what I mean is if do you think is better have digital/analog conversion performed by Lumagen (as in the first solution) or by Moome VIM card.... In first option, Mux HD is only for switching and HDCP stripping and then the Lumagen for processing and conversion to analog (RGBHV to Marquee)
For HD audio, I use analog out from my BD player (Samsung 2500), as my Receiver, that is a very nice Onkio Integra DS 989, has no HDMI input...
| Posted: Sun Nov 29, 2009 8:45 pm Post subject: |
the lumagen does nothing to degrade the picture either way you choose to use it, as an D/A converter or as a scaler in the Digital domain. The thing the lumagen is worth its money for is its 11 point gamma adjustment. AND!!!! its not just at the typical 0,10,20,30...100 points you can change the points your adding the gamma too, so say you need it at 2.5 IRE, 5 IRE, 8 IRE, and 15 IRE you can change the ones that dont need gamma like 50 and up and use them for the lower IRE's.
| Posted: Sun Nov 29, 2009 10:26 pm Post subject: |
Athansios |
+1
what he said!
_________________ Follow my blog
Annyla
| Posted: Mon Nov 30, 2009 9:23 am Post subject: |
Fully support most HD(High-Definition) video encoder and HD decoder, Tipard HD Converter is the fast HD Converter to convert HD video to general video, convert general video to HD video, convert among HD videos, such as HD TS, HD MTS, HD WMV, HD MPG, HD MPEG4, H.264/AVC , HD AVI, HD ASF, etc. Moreover, Tipard HD Video Converter has audio conversion and audio extraction functions to convert among audios, extract audios from general videos and HD videos to AAC, AC3, AIFF, AMR, AU, FLAC, MP3, M4A, MP2, OGG, WAV, WMA audios.
*Key Features*
1. Support most HD video encoder, HD decoder and general video
Support among HD videos conversion, such as HD TS, HD MTS, HD WMV, HD MPG, HD MPEG4, H.264/AVC , HD AVI, HD ASF, and so forth; general videos to HD video conversion, HD video to general video conversion.
2. Set video effect
Set the Brightness, Contrast and Saturation of the video.
3. Provide Deinterlacing function
Convert interlaced video to the progressive video in order to optimize the video effect.
4. Trim video length
Clip any segment of the video exactly.
5. Crop the playing region
Adjust the playing region of the video to fit for the player and user’s taste.
6. Merge clips into one file
Provide to join separated video files into one.
7. Customize output settings
Set the Video Encoder, Resolution, Frame Rate, Video Bitrate. You can also directly input your own resolution as the form of “XXX*XXX”; Set the Audio Encoder, Sample Rate, Channels, Audio Bitrate. You also can save all the output settings as your preference, which is saved in the user-defined column automatically.
