Marquee 8500 tube issue update **Losing all hope**
Goto page 1, 2, 3  Next
deewaan1
Posted: Wed Nov 25, 2009 5:49 am    Post subject: Marquee 8500 tube issue update **Losing all hope**
Hey all. Thanks for all the help so far. Still got a problem with my tubes though. I have what appears to be two separate sets of scan lines overlapping each other but offset by about a half inch to the left if looking into the tube face. Only one can be controlled by the remote in setup. I have more detail in my original post plus a picture of the tube.
This is the link to the original post
https://www.curtpalme.com/forum_archived/viewtopic.php@t=17866.html
Here's what I've done lately:
I've completely taken the projector apart an cleaned all connections ( connectors, chips and sockets, cable terminations ) from every board including the neck boards. I've tried swapping the HDM, Focus board, VIM, Color Correction, Conv board, Verticle board, Astig board, Video/S-video input board, Moome card, CLM board, HVPS, LVPS. I have also swapped the neck boards between the three tubes. I even tried swapping the ribbon cables to the back panel boards. All this and nothing still has the same issue. No improvement. Tomorrow I am going to get another high voltage splitter and try that. I am also thinking of trying to disable one tube at a time and see if one tube is possibly sending some feedback into the system which is causing the second set of scan lines. What is the best and safest way to disable a tube and still be able to power up the projector to see if the other tubes are still affected?
Posted: Wed Nov 25, 2009 6:04 am    Post subject:
Ok I just saw you swapped out the S-Viedo board. Does it do it with out this board in? I mean did you try running the PJ with out that board.
Also try running it with as many board out of the PJ that aren't needed to turn on, so remove the FCM,Unplug the SAB and CVA Cables and remove the S-video board and the CCM and if you really have to the SWA on the CLM. the PJ will run this way. and maybe, Just maybe you can find out which board or connector on the back plane or MB could cause this.
Too bad you dont have a scope to look on the Vim video signal or on the neck board on one end of the Big orange resistors while having a pattern on. like the greyscale or just a full field pattern. Then we could see where its comming from.
Aslo does it do it with the internal patters too?
Posted: Wed Nov 25, 2009 6:06 am    Post subject:
Oh and try it with one VNB not connected , remove the black Umbilical cord form one VNB at a time.
antorsae
Posted: Wed Nov 25, 2009 9:44 am    Post subject:
Interesting.
One question: what is the VAC range on those pins? I have a USB oscilloscope and logic analyzer however the oscilloscope can only take +- 10 VAC input... and I don't want to fry it feeding it more than spec'd.
Suggestions?
Posted: Wed Nov 25, 2009 1:26 pm    Post subject:
on the VIM its ok from the video signal and most any other points. but not on the VNB's those resistors are the 85 volt rails but the video goes through them.
So if you put up say a greyscale pattern from the internal video you'll see the stair step on the scope. and you can actually set up G2 and drive this way by looking at the distance of each step. hey should all be equal in distance or hight . I never did this but did use the scope on that part to diagnose a Video problem and its one of the things i noticed.
And for his problem here in this thread he would be able to see if something is wrong if there are any weird variations, like a double stair step patter on the scope. If its not there then its something not in the video chain .
jcmccorm
Posted: Wed Nov 25, 2009 2:39 pm    Post subject:
Is there an image on that second set of scan lines? Could it be that the retrace isn't being blanked?
Cary
Posted: Wed Nov 25, 2009 2:42 pm    Post subject:
Cary
Thats a good point but he replaced all boards that would take care of that. But not sure if he used them in unison with each other. Doesn't the VIM take care of blanking along with the CLM? Not sure if he used a new clm and new vim together. I doubt that it be both boards together to cause an issue but hey, you never know.
I wish TSE would comment on this one.
Posted: Wed Nov 25, 2009 2:43 pm    Post subject:
I've been wondering whyTim no longer post to these threads, or don't post as often as you used to... now I think I understand.
Measure your G2 at either of the neck boards with a meter. Compare that reading to what would be standard.
Remove all three tubes, boards, etc until you have the mother board in your hand. Inspect and clean with 90% Isopropal alcohol, Do not use denatured alcohol here. Or go to Lowes and get a can of CRC Contact cleaner.
Use a small brush (tooth brush) and saturate the entire board brushing more in areas where contacts are.
wrap-around image problems are rarely in the video chain. And the best way to run them down would be to scope the deflection circuit for proper timings. But in this case, the image on the tube is doing what a scope would do with the exception being able to show what the timings are.
The problem here, based on what I'm able to see in the image shows as a deflection problem. Since the HDM has been swapped out numerous times. rule it out as well as the other boards that were already swapped............
Posted: Wed Nov 25, 2009 2:45 pm    Post subject:
Cary
Yep, or the video circuit is not getting the pulse from the deflection circuit. But still, wrap around is usually caused from the horizontal deflection side of things or neck boards (which have already been ruled out).
Posted: Wed Nov 25, 2009 2:51 pm    Post subject:
It has been mentioned in the other thread to measure the G2 values and compare to standard. Also it has been mentioned it could be a mother board problem or Back plane. He said he tore down the entire PJ and cleaned the contacts for all boards, however it did not go into to detail if he in fact cleaned the mother board and back plane. I say its one of the mother boards also.
So what do you mean you understand why Tim doesn't post much?
Posted: Wed Nov 25, 2009 2:57 pm    Post subject:
This is his best description of the problem from the other thread.
Hi. Swapping the neck boards didn't change anything. And I did the mod and that didn't fix this problem either. The problem does seem worse though. It is as if I have two sets of scan lines on the tubes. One just offset and to the lower left of the other with the projector mounted on the ceiling. The second set is not controlled by anything such as blanking or convergence. Is is behind the controlled image. And it is right against the right edge of the tube face. when an image is projected through the projector it is displayed only on the controlled set.
I find it interesting that he says there are two sets of images but only the one can be controlled by any electronics and the second scanned image is unaffected. Never heard of that before so the experts here may have more insight.
Posted: Wed Nov 25, 2009 2:58 pm    Post subject:
You would have to know Tim to understand that comment. I was just typing out load - my bad.
On one of Williams blended Marquees, we had to replace the mother board to solve a problem we were having. Sometimes cleaning will not solve a problem caused from contaminated glycol. It's best to change the board.
Posted: Wed Nov 25, 2009 3:00 pm    Post subject:
He needs to post a better image. It's hard to tell what's really going on with the double image claim.
Posted: Wed Nov 25, 2009 3:21 pm    Post subject:
Is this only on the blue?
If you pull up a grid do you have 2 grids?
If you mute the pic does the other remain.
What does an actual image look like?
Some pics of test pattern and image?
If you run blanking as far as it goes, does it blank both images or just one?
Posted: Wed Nov 25, 2009 3:31 pm    Post subject:
I agree, an external grid pattern pic would be more helpful and or a small video of him adjusting the image size to see what happens to the secondary image.
Posted: Wed Nov 25, 2009 3:38 pm    Post subject:
I understand why for more then one reason.
deewaan1
Posted: Thu Nov 26, 2009 3:58 am    Post subject:
Yes I've tried running it without the S-video board in as well as doing the same with other boards. No joy. Yes it does this with internal patterns as well. Today I tried the high voltage splitter and disabled one tube at a time to see if one of them was causing the problem. That didn't do anything for this problem but now my blue tube is very bright and I can't control it with contrast or brightness. It stays full bright and has a criss cross line which runs from the top down at an angle back and forth across the tube face. This showed up right after I swapped in the other HV splitter. It seems with every step I take to troubleshoot the original problem other things keeps popping up. I have been very careful to disconnect power with each step I takein troubleshooting so I don't know what's up with that tube now. I think this thing just wants to die. The last thing to try is the upper motherboard I guess. It's just alot of trouble to get at it and I don't have one to swap in. Don't know what on it would cause this problem.
deewaan1
Posted: Thu Nov 26, 2009 4:00 am    Post subject:
Cary
No there isn't an image on the second set. It's just there in the background.
Posted: Thu Nov 26, 2009 4:07 am    Post subject:
Check the HV lead on the blue tube, any leaks possibly?
deewaan1
Posted: Thu Nov 26, 2009 4:08 am    Post subject:
It's on all three tubes. If I pull up a grid I have only one. Not sure what you mean by mute the pic. When video is displayed the scan lines in the back are just lines no image. I will try to get some other pics on here as soon as I can. When I run the blanking in and out it only blanks the one set. The other remains in the back.
Page 1 of 3
