red focus pot broken? Nec PG...
benareeno
Posted: Mon Nov 16, 2009 4:11 am    Post subject: red focus pot broken? Nec PG...
Setting up this pg and the focus pot for red seems to have no stop points...and, of course..the pot makes no difference to the on screen focus. ALso, the menu for focus doesn't do anything for red either....I guess I need to repair my deflection board?
Posted: Mon Nov 16, 2009 4:37 am    Post subject:
Yep, sounds like you need a new pot. Do you need the value of it?
benareeno
Posted: Mon Nov 16, 2009 5:33 am    Post subject:
indeed....any info is appreciated. Is putting in a new pot something that will require some soldering?
Posted: Mon Nov 16, 2009 5:35 am    Post subject:
Yes, and delicate soldering at that. You still need the value or are you going to have someone else change it for you?
benareeno
Posted: Mon Nov 16, 2009 5:37 am    Post subject:
I'll do it, or I'll bring it into work and let one of the pro's do it...what part of the soldering is delicate? Is it a very small solder?
Posted: Mon Nov 16, 2009 2:44 pm    Post subject:
The soldering is delicate because you dont want to overheat or prolonged heat to a variable resistor because you can damage it. Other wise its pretty straight forward.
Elaine Benes
Posted: Tue Nov 17, 2009 1:34 am    Post subject:
Let the pro's do it, if you have access to pro's, it'd be a shame not to take advantage of that great resource...
