locoman
| Posted: Sat Nov 14, 2009 12:46 pm Post subject: Service Manual for Barco 708 |
Hi All,
I need a service manual for my barco 708 to diagonse my "HTHD" failure. I've replace all three tubes and on the first start I got this failure. Can anyone help me or any suggestions?
Thanks!
Hein.
| Posted: Sat Nov 14, 2009 3:49 pm Post subject: |
Sorry,. I don't post late model set s/manuals on the site yet. Since I make my living repairing boards, I feel it takes business away from me if I post the later manuals here.
Are any of the red LEDs on on the deflection board?
locoman
| Posted: Sat Nov 14, 2009 4:36 pm Post subject: |
| Curt Palme wrote: | Sorry,. I don't post late model set s/manuals on the site yet. Since I make my living repairing boards, I feel it takes business away from me if I post the later manuals here.
Are any of the red LEDs on on the deflection board? |
Hey Curt. Yes, only the d28 is on.
| Posted: Sat Nov 14, 2009 5:51 pm Post subject: |
Check to make sure you didn't plug a yoke connector 1 pin off. I've done that lots of times.
locoman
| Posted: Sun Nov 15, 2009 7:46 am Post subject: Re |
I've tripple checked all my connections and they are properly connected. I think my smsp is faulty. When I power it back on, you can hear a soft repeated tick noise right after the +HTHD led goes off.
| Posted: Sun Nov 15, 2009 8:04 am Post subject: |
Was everything working OK before the tube swap ?
Also did you install new or used CRTs.
locoman
| Posted: Sun Nov 15, 2009 10:10 am Post subject: |
Hey Tom. Yes, it was working perfectly fine. I've replaced the tubes the tubes with working used ones, I bought from Ebay some time ago.
| Tom.W wrote: | Was everything working OK before the tube swap ?
Also did you install new or used CRTs. |
Elaine Benes
| Posted: Sun Nov 15, 2009 2:19 pm Post subject: |
Did you swap back in the known good working tubes you took out to eliminate the possibility that those ebay tubes were perhaps different than they were described as being ?
It is rare, but the occasional ebay seller will offer assurances on products that they really have no clue about...
locoman
| Posted: Sun Nov 15, 2009 6:55 pm Post subject: |
| Elaine Benes wrote: | Did you swap back in the known good working tubes you took out to eliminate the possibility that those ebay tubes were perhaps different than they were described as being ?
It is rare, but the occasional ebay seller will offer assurances on products that they really have no clue about... |
Yes, I have and the problem persist. I've gone through all the connections today and can't think of anything or way I could have caused it to fail. I guess I'm gona have to find a smps replacement to narrow the problem down.
