How To Repair A Broken Pin On a CRT Tube
Arctic Dweller
Posted: Fri Nov 06, 2009 4:41 am    Post subject: How To Repair A Broken Pin On a CRT Tube
I was swapping out Neck Boards between the Green and Blue tubes on my SONY G70 to determine if the Green CRT tube was faulty. (the Bias control would not function on the Green tube) In the process, a pin came off the Blue CRT tube that was critical to the Blue tube's performance.
I investigated using a Silver-based epoxy to "glue" the pin back. However, the technician I spoke with from the Silver Epoxy manufacturer advised it would not be strong enough, nor hold it under the temperature conditions of a CRT tube.
I then decided I had nothing to lose and decided to try and solder the broken pin back together. The pin had separated fairly deeply down into the hole of the plastic end and glass end of the tube.
The bottom-line is that the repair worked perfectly the first time!
I have attached an MSWord file with the Procedures as well as a Diagram (the details were too small to properly photograph).
Hopefully, none of you ever have to try this procedure but, if you do, here's how it worked.
God Bless, John
CRT Pin Repair.doc
 Filename:  CRT Pin Repair.doc
 Filesize:  33.5 KB
 Downloaded:  605 Time(s)
Posted: Fri Nov 06, 2009 10:39 pm    Post subject:
That's pretty impressive John.
Kal should add this to the procedures.
Posted: Fri Nov 06, 2009 11:17 pm    Post subject:
Yes he should. Congrats, I've never done that!
Posted: Sat Nov 07, 2009 12:36 am    Post subject:
Great Idea! Yes add this to the Faq's page!
Posted: Sat Nov 07, 2009 2:05 am    Post subject:
Nicely done Smile
Just be very careful if you have to pull the neck board off again. I suspect that the solder may hold up better under compression than under tension Wink But I suppose if the pin comes out again you can just resolder it again too.
Arctic Dweller
Posted: Sat Nov 07, 2009 3:02 am    Post subject:
Thanks guys for your kind remarks.... I am humbled by your words.
God Bless, John.
VideoGrabber
Posted: Sun Nov 08, 2009 5:51 pm    Post subject:
John wrote:
> I have attached an MSWord file... <
Apparently, I'm the only one not seeing this attachment?
- Tim
Arctic Dweller
Posted: Sun Nov 08, 2009 11:00 pm    Post subject:
Hi Tim:
In the first posting of this subject, there is a "boxed area" with the heading: "CRT Pin Repair.doc"
At the bottom right-hand side of this boxed area you should be able to see a symbol of a paper clip with the word "Download" in blue font.
Click on the word "Download" and you should be able to retrieve the Procedures and Diagram.
It has been downloaded 102 times, thus far, so the download function is working.
God Bless, John.
VideoGrabber
Posted: Mon Nov 09, 2009 12:22 am    Post subject:
John,
thanks a lot. I see it now (and was able to download the doc), but there was no trace of the box there when I initially posted. Honest! Smile
I have no clue why that would be the case, but since it's working now, I guess it's a moot point.
- Tim
