clport
| Posted: Sun Oct 25, 2009 3:32 am Post subject: Help - Barco 1100, only green and red lenses light |
I bought two Barco 1100s a few years ago. Recently the mounted projector would not turn on. After unplugging it and plugging it back in, it powered up but only the green and red lenses would project an image. I need some help troubleshooting the problem so I can hopefully fix it with parts from my spare. Any suggestions?
| Posted: Sun Oct 25, 2009 6:58 am Post subject: |
Are you just looking at the internal menu ?
jantje112
| Posted: Sun Oct 25, 2009 2:09 pm Post subject: |
Barco 1100, well known for tube shortage.. So it could be the tube.
clport
| Posted: Sun Oct 25, 2009 3:20 pm Post subject: |
| Tom.W wrote: | | Are you just looking at the internal menu ? |
Yes, all I am getting is the internal menu - no input signal.
| Posted: Sun Oct 25, 2009 9:12 pm Post subject: |
If you are only looking at the internal menu then only the green and red will light up. Pres the "Adjust" ( I think it says Adjst) and all three tubes should light up with a test pattern.
clport
| Posted: Sun Oct 25, 2009 11:26 pm Post subject: |
| km987654 wrote: | | If you are only looking at the internal menu then only the green and red will light up. Pres the "Adjust" ( I think it says Adjst) and all three tubes should light up with a test pattern. |
Thanks, that was the problem.
