Marquee 8500 blinking off
PJMoore
Posted: Fri Oct 16, 2009 11:50 pm    Post subject: Marquee 8500 blinking off
My good friend with a ceiling mounted Vidikron Vision 2 ( Marquee 8500 ) is experiencing what appears to be some sort of intermittent HV failure. The unit has run flawlessly for years, and has only recently begun to show this behavior. All three guns shut off for anywhere from 3 seconds to 11 seconds. All three tubes then turn back on for a random time period between 10 seconds and 10 minutes. When the tubes turn on, the raster is unfocussed and oversize. Within 1 to 2 seconds the image reduces to normal size and focuses again. Convergence appears to stay good through all of this, but it is definitely defocussed on light up. When the unit is first turned on, it works fine for up to 5 or 6 hours before this somewhat random turn off / turn on pattern happens.
I checked the two cards, removing them and DeOxiting the connectors while I had them out. I saw no evidence either was loose. I had previously cleaned them and used nylon strapping tape to ensure a solid up-pressure. I moved to the LVPS, removing it, cleaning the fan blades of light dust, and checking for any signs of burn damage. I saw none.
I powered the unit back up, and waited for tito again start the on / off cycle, this time observing the LEDS on the rear panel. None were lighted.
Any ideas what we should do next ( besides sending large sacks of unmarked bills to Curt? ). I do have a spare Marquee 8500 with earlier version cards available if I need to swap cards. The only spare HVPS I have is in my theater, and I just hate to swap that into his unit if I can avoid it.
Any ideas would be much appreciated.
Posted: Sat Oct 17, 2009 12:21 am    Post subject:
It could be the HVPS, or one of the VNB's causing HV shut down, or the VIM. But also check the Connectors on the CLM to the DPB and those chips also.
if you have some spare VNB's swap out one at a time and leave in the PJ to see if it happens again with that known good VNB, if so then swap out the rest.
Posted: Sat Oct 17, 2009 5:54 pm    Post subject:
HVPS almost certainly. That shrinking and defocusing with intermittent black-outs is a good indication.
PJMoore
Posted: Thu Oct 29, 2009 6:41 pm    Post subject: Fixed
I pulled the CLM, removed and cleaned all chips and connectors, and then did the same for the VIM.
Put it all back together and it is running fine. Thanks so much for the advise.
Posted: Thu Oct 29, 2009 7:19 pm    Post subject:
Your welcome!
Posted: Fri Oct 30, 2009 12:17 am    Post subject:
these types of problems are difficult. A lot of times people will clean something and everything will be fine then problems start a few days or even weeks later. I hope yours is fixed for good.
J Kildare
Posted: Sat Oct 31, 2009 2:51 am    Post subject:
To the OP, I understand the problem has been corrected but for others performing future searches I will add that TB95-07 is also a good read.
I know I've got symptoms 1,3,and4. Sad
Jim
PJMoore
Posted: Thu Nov 26, 2009 12:44 am    Post subject: Not that lucky
Well - it worked for a while, but the problem is back. I guess it is time to start swapping boards. I have some spares. any suggestions as to the most likely to least likely culprits?
Posted: Thu Nov 26, 2009 3:35 am    Post subject:
Might be time for a new CLM. OR you might have to do a initilization on that one. after some time the meory and software becomes corrupt. and an initilization fixes it, but not always. its worth a try especilay if you have the marquee librarian to down load your settings.
nashou
Posted: Thu Nov 26, 2009 3:40 pm    Post subject:
Almost any board can trigger the HV shutdown, but the VIM, CLM or neck boards would be most likely. Outside of a defective HVPS of course.
dturco
Posted: Thu Nov 26, 2009 3:55 pm    Post subject: Re: Not that lucky
No I sure don't. Surprised
http://www.hulu.com/firefly
Posted: Thu Nov 26, 2009 4:05 pm    Post subject:
I hear dturco has gotten really good at swapping boards though, huh? Very Happy
PJMoore
Posted: Thu Nov 26, 2009 4:41 pm    Post subject: Step one
I certainly wish this projector was floor mounted, and had a standard Marquee case. This fiberglass beast (Vision 2) is just oversized enough that none of the cards will come out unless the case is removed entirely. The easiest to get to was the VIM, so I swapped it first. If this isn't it, I will next do the neck boards, then the CLM re-initialize / reload, then swap the CLM, then the HVPS. I am waiting to the last on the HVPS, since the only spare I have is in my working unit at my house and I just hate cannibalizing my own system.
Film at eight with fingers crossed. Thanks for the ideas everybody.
Curt - this is that Chattanooga Marquee you asked me to look at last year - the one that went "psychedelic" - turned out to be the scaler. Did you ever get the old scaler we sent you working? I was just curious.
Posted: Thu Nov 26, 2009 5:09 pm    Post subject:
Right, I remember that one. Yes, I did get the scaler going, a bunch of caps were bad.
PJMoore
Posted: Thu Dec 03, 2009 7:00 am    Post subject: not fixed yet...
Well - it's not the VIM, or the neck boards. Next I will swap out the LVPS, then the CLM. Onward, into the fog.....
antorsae
Posted: Thu Dec 03, 2009 10:27 am    Post subject:
My suggestion is to swap the HVPS, in case you have one.
PJMoore
Posted: Thu Dec 03, 2009 2:01 pm    Post subject:
Unfortunately, I don't have a spare. I suspect it is the HVPS, since it appears to be heat related. The unit fires up normally, then after a time, begins its flashing mode. All three guns turn off, then turn back on with enlarged and unfocused raster, then it quickly shrinks to normal and focuses, then all three guns shut off again and the cycle repeats.
The first time I timed the failure at about 6 hours. Each time I try a different card, the time frame shrinks. It is now down to 1 hour. That seems like a heat related failure that is getting worse.
Posted: Thu Dec 03, 2009 2:48 pm    Post subject:
Well like I said back in OCt. it really sounds like the HVPS. Wink My friends machine locally did the exact same thing, and like yours, the problem got worse until it finally died. Easy repair for a couple hundred bucks
PJMoore
Posted: Thu Dec 03, 2009 3:01 pm    Post subject:
Thanks Dragan - I agree then and now, but was hoping on hope it wasn't the HVPS. My friend is teetering on the brink of digitalness, and I hope I can yank him back from the abyss. I bought a used HVPS from Bill Blue, and it worked fine for about three months before going t*ts up. I didn't mind, knowing the nature of vintage equipment. Its another thing to make recommendations to a non-technical friend, however. I wish there was some way to tell if a HVPS was going to last a while before buying it. In any case, does anyone know where I might find one and what it might cost? I suspect I will need to be having a conversation with my friend about a HVPS soon.
Posted: Thu Dec 03, 2009 4:43 pm    Post subject:
PJMoore wrote:
My friend is teetering on the brink of digitalness, and I hope I can yank him back from the abyss. .
that's an interesting perspective, I used to actually be strongly inclined to convince people of this or that tech. being superior and why they should go that way etc. I've slowly gotten away from it and found it's more enjoyable to talk to and deal with people who already like the same technology's I do. If your buddy wants to go DLP then just help him pull down the MArquee and get it into the hands of someone who is interested in it. The CRT is great but if it's not something he appreciates beyond simply a big screen then go DLP.
Recent thread on AVS is a perfect example. I helped a guy get a marquee 6 years ago, it had the P14 problem and burned out a green. I offered to fix the LVPS a number of times but he ignored it and then burned out a Red. PJ was never set-up very well and shooting down from a 12 foot cieling in all all-white room with many windows etc. DLP is really perfect for situations like that, I was happy to hear he switched.
