Frequency Out of Range
jbardwel
Posted: Sat Oct 10, 2009 7:36 pm    Post subject: Frequency Out of Range
I set up my HD Fury through my HD Leeza.
I attached it to the RGB passthrough and then using my existing (long) RGB cables to send the signal to my mounted projector.
The picture tries to resolve but in the end the project gives up and says Frequency OUt Of Range.
How should I proceed?
Posted: Sat Oct 10, 2009 7:48 pm    Post subject:
What resolution and refresh rate and what projector ???
jbardwel
Posted: Sun Oct 11, 2009 12:02 am    Post subject:
My projector is a Sony VPL-VW10HT.
The HD Leeza is set at 720p at 60hz.
I am taking the output out of the DVI out and putting it back into the RGB bypass to then go out the RGB cables.
Joe
Rolls-Royce
Posted: Thu Nov 12, 2009 8:03 pm    Post subject:
If that's an original HDFury, it can't drive long cable runs. Your description wasn't clear, but you should have the Fury close enough to the projector to use the short cables it came with between it and the projector. Does your passthrough have a cable driver? If not, or it's an unpowered passive one, you should be using one that does.
....Royce....
jbardwel
Posted: Thu Nov 12, 2009 8:10 pm    Post subject:
I have the HDFury. I since purchased a box to run the signal over the cables (long). Everything was working fine and then the HDFury gave me trouble. It stopped working. Then I noticed it would work if I unplugged it. Strange. Not sure the value of plugging in the HDFury?
