picree
Joined: 31 Mar 2006 Posts: 351 Location: Johnson City, TN
| Posted: Thu Sep 17, 2009 11:49 pm Post subject: Source Samsung DTB-H260F RGB? YPrPb? REC601? REC709? |
Some source devices have REALLY good tech support (Oppo, Lumagen). Others don't. I've searched the internet. I'm connecting a HD OTA box to a Lumagen HDP Pro and want to get all the settings correct. I think I know what the standards are but not all sources follow the standards. I'm trying to determine:
1) When using an HDMI to DVI cable what color space does the OTA box convert to? It should be RGB. Is it?
2) Is the color space the same for all resolutions?
3) Does the color space change when the OTA box switches from an HD program to an SD program?
4) What black level does the HDMI output? Should be 7.5 IRE. Does it convert it to 0 IRE when using an HDMI to DVI cable?
5) Are any of the answers different if I was using the component outputs (less desirable).
6) Is any of the answers different if I use an HDMI to HDMI cable into a switcher and how can I tell?
7) Of course the answer to any of these questions begs the last question which is; What should I set the Lumagen input for?
All these questions could be answered easily if there was a device that could be connected to the source that could enumerate not only the resolution and frequency but also, black level and color space. Is there any way to get that information from the Lumagen? Is there any device that can mimic the Lumagen's EDID and report the results?
I know many of these questions are probably unanswerable for sure so, does anyone even have a "most likely" answer? BTW, if you haven't noticed, I HATE digital handshakes and HDCP The root of video evil!
_________________ MAIN THEATER: (JVC RS2000; Yamaha UDP-LX500; Yamaha RX-V2400; Lumagen Radiance Pro, Vertex)
SECOND WII-ATER: (BG808; WII; Oppo 971H; Moome external box; BG-DVI transcoder; tse gamma box; Extron)
| Posted: Fri Sep 18, 2009 2:40 am Post subject: |
You know I have one of these but I've never bothered to look at any of that. I was to busy watching HDTV
Mine's hooked up to an HDFury1 into an IFB12 and onto the Sony D50 at my G/F's place.
Since the back panel has a hard switch to set the resolution I don't think anything changes. BUT that's just an observation.
Good luck with your quest.
