SonyDH500 and HDFURY2
crazybake
Posted: Fri Sep 04, 2009 12:41 am    Post subject: SonyDH500 and HDFURY2
I have simple setup. DVD player and Cable box connected to the inputs of a Sony DH500 receiver via component video in. These are connected via component out to a Viewsonic PJ550 projector (with component in, s-video in, and RGB in via DB.) I recently have been using an AppleTV so I purchased an HDFury2 (FW 1.51 with blue QC sticker) so that I could connect to the project via RGB input.
I connected the AppleTV via one of the HDMI inputs of the Sony receiver and the HDMI output to the Fury2 into the projector via the provided VGA cable. When I first started the setup the blue light came on, but all was black - no video. Then and a few times within the first five minutes, I saw a picture for a second then flick away - then to black. Now, there is no blue light and the projector sees no input.
I tested the HDFury2/Projector direct to the AppleTV and it worked great - but it is extremely HOT!
Any ideas on why this sequence would happen. I did not see anything on Sony's site.
thanks
Posted: Fri Sep 04, 2009 3:40 am    Post subject:
Do you have the power supply connected?
crazybake
Posted: Fri Sep 04, 2009 5:34 pm    Post subject:
No, have not used the power supply in any case (even when it worked directly connected to AppleTV). I will try that. Also, is the extreme heat normal for the HDFury2? I read that the FuryHD got very hot.
