Calibrating a Sanyo Z2000 LCD Projector, need help.
Pitou
Posted: Mon Aug 24, 2009 2:26 pm    Post subject: Calibrating a Sanyo Z2000 LCD Projector, need help.
Hello,
This is my first post here!
I already read the excellent guide on this forum here:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10457.html
I have couple question regarding how to use the different menus items in the Z2000. I'm using an Eye-One LT probe along with the ColorHCFR software.
1- Which mode should you start with? (Pure, Natural, Brilliant Cinema)?
2- Should I start with a 50% IRE pattern and adjust the RGB parameters.
3- Then should I try to adjust all 0 - 100% IRE steps using the custom RGB Gamma?
4- For colors, Can I just play with the Color/Tint and the CMS and target each primaries and secondaries to match the "triangle" points?
5- Any other hints about Lamp mode, HDMI mode, Brightness/Contrast or any other menu item, you could think of?
I did an attempt, see .chc attached. The problem is that I'm getting low FL, around 4. I did align the probe at about 25 inches from the screen pointing at it. But if I put the probe closer, like 3-4 inches, as suggested in the guide, I only get around 8 FL.
I really feel I can obtain some good results, but really not sure how to proceed.
Thank you
Pitou!
User_Image2.zip
 Filename:  User_Image2.zip
 Filesize:  3.69 KB
 Downloaded:  3 Time(s)
