| Posted: Sun Aug 09, 2009 3:03 am Post subject: Specs for externa\l FULLHDbox? |
I put a few HDMI boxes into a carrying case, and the power supplies got mixed up. WHat are the specs for the FULLHD unit? It is 5 volts at 2 amps, right? That's the power supply that comes with them? Want to make sure before I power up.
THanks!
moome
| Posted: Sun Aug 09, 2009 4:11 am Post subject: |
| AnalogRocks wrote: | | https://www.curtpalme.com/forum_archived/viewtopic.php@t=17241.html |
thanks AnalogRocks, that's correct.
actually to get more clean power for EXT, the EXT internal use linear regulator,
so the power input range is 6-9V, but 7.5V is the best for EXT. 9V will to hot for it~
| Posted: Sun Aug 09, 2009 4:45 am Post subject: |
You're welcome Moome.
| Posted: Tue Aug 11, 2009 1:14 am Post subject: |
THanks, I guess that's why my 5 volt one isn't getting me an image.
moome
| Posted: Wed Aug 12, 2009 3:50 am Post subject: |
| Curt Palme wrote: | | THanks, I guess that's why my 5 volt one isn't getting me an image. |
please also check current capacity of the linear adaptor, >1A will be better~
