Problem with displaying with HDFURY2 on Sanyo Z5 through inp
bryanbblack
Posted: Mon Jul 27, 2009 3:36 pm    Post subject: Problem with displaying with HDFURY2 on Sanyo Z5 through inp
I have a Sanyo Z5 HD projector which is cabled with component inputs. I have a VirginV+ cable box which has HDMI output which I need to use to download HD movies. All works fine through the component cables and I can get HD picture. I have bought the HDFury 2 and have hooked and configured the cable box to output to HDMI and the blue LED is lighting up so the signal must be coming out of the HDFury 2 but no picture through the projector. I have sent the first one back to the reseller in the UK and they said it was faulty and sent another one which has firmware 1.5 on the outside. I am in the UK.
Does anyone have any suggestions on why it won't work.
Posted: Tue Jul 28, 2009 3:29 am    Post subject:
Do you have the power supply? Do you have the side switch on the HDFury2 set to YUV?
bryanbblack
Posted: Tue Jul 28, 2009 9:03 am    Post subject:
yes I do have a power supply. I will doublecheck I have set to YOUV. Also I recehecked and found that the firmware is actually 1.51 and there seem to be some problems with that version and some projectors and that it needs a fix. Is that right?
