BG1208 Deleting Blocks
tri_joel
Posted: Fri Jul 24, 2009 6:16 pm    Post subject: BG1208 Deleting Blocks
Thanks for the help with the crosshairs. Forgive me for asking so many questions, I just installed my second BG1208, it has more hours than the previous 1208 but has brand new tubes installed. I made some lense adapters for a set of HD145's I had on hand.
Anyway, when I delete all blocks it says to confirm that I want to delete all 32 blocks. I confirm, but each time I try to do a fresh set-up from scratch and delete all blocks, it wants me to confirm deleting all 32 blocks. What gives?
www.vawinesnob.com
Ile
Posted: Sat Jul 25, 2009 9:08 am    Post subject:
It probably don't know if blocks are created or not, it just delete all blocks anyway. Very Happy
You can check is there any actual blocks with copy block...
tri_joel
Posted: Sat Jul 25, 2009 9:24 pm    Post subject:
I'll check, but it doesn't sound like I should be concerned.
Next problem-
I cannot get astig or focus right on the blue. I get blue ghosting or haloing (not sure which is the proper term).
The astig seems to be a problem on all three, even after adjusting the magnetics, I still need to adjust electronic focus all the way up to 97. I'm not 100% sure I'm doing the magnetic astig correctly, the BG1208 is different than Curt's ultimate set-up guide which is based on an NEC. The two tabs turn around the tube, and the tabs turn on axis - I got that part figured out.
www.vawinesnob.com
Ile
Posted: Sun Jul 26, 2009 6:51 am    Post subject:
Check last two pages for instruction for astig and focus yoke position in neck...
http://www.curtpalme.com/docs/BarcoGraphics808s_CRTReplacementProcedure.pdf
tri_joel
Posted: Sun Jul 26, 2009 2:24 pm    Post subject:
Thanks Ile!
I was starting to think about taking this PJ down and putting the previous one back up. I thought maybe I was in over my head - but I'm getting it now.
www.vawinesnob.com
