PlasmaPZ80U
| Posted: Tue Jul 21, 2009 11:14 pm Post subject: Grayscale readings below 30 IRE |
The Grayscale and Color Calibration for Dummies guide suggests that a majority of colorimeters (such as my i1d2) don't provide accurate, reliable readings below 30 IRE. It also mentions that the i1d2 can provide reasonably accurate readings all the way down to 20 IRE under "Which meter is right for me?"
The main statement is:
"The low end (especially 20 IRE and below) is especially problematic on just about every display. In fact, contrary to what we've said before, you're almost better off using your eyes to judge the readings at 10 and 20 IRE as most sensors (including the more expensive ones) simply don't do a very good job of measuring light output at the low end. If your greys at 10 and 20 IRE look reasonably grey and 30 IRE measures close to D65 then good enough!"
Should I just look at 30 to 100 IRE when calibrating grayscale on my plasma TV via a i1d2 or should I include 20 IRE as well?
kal Forum Administrator
| Posted: Wed Jul 22, 2009 1:39 am Post subject: |
I'd use 30 and 80 myself (as my guide states) but you still want to maybe check how everything else (from 10 to 100) seems to doing and then go back and itterate. In the end you have to keep the idea in your back of your head that your meter may not be reading right at 10 and 20 IRE.
Remember also that 20 IRE on one projector may only give you half the light output as 20 IRE on a different projector. IRE is relative. It's a percentage of total light output. So some people may get better (more accurate) readings at 20 IRE than others simply because their projector puts out more light at 20 IRE so the results are more reliable. In fact, 20 IRE on one projector may put out more light than 30 IRE on a different projector.
So it's important to remember that just because 20 IRE readings seem to work accurately for one person it doesn't mean that they'd be accurate for another person on a different display (even if the same meter is used!).
This is why I go with 30 IRE as the low point as most displays will put out enough light to get good readings on most meters.
Hope this helps!
If you really want good 10/20 readings, buy a Chroma 5! See: www.curtpalme.com/Chroma5.shtm
| Posted: Wed Jul 22, 2009 3:45 am Post subject: |
| kal wrote: | | So some people may get better (more accurate) readings at 20 IRE than others simply because their projector puts out more light at 20 IRE so the results are more reliable. In fact, 20 IRE on one projector may put out more light than 30 IRE on a different projector. |
Meaning, one projector may have more total light output at 100IRE than another projector, or its gamma (basically determining how bright X IRE is compared to 100IRE) might be different, so its 20IRE might be brighter than the other projector's 30IRE. But if both projectors are putting out the same lumens at 100IRE, and both have roughly the same gamma, then their 20IRE or 30IRE light output should be pretty much the same.
But whatever -- the meter doesn't know or care whether it's 20IRE or 30IRE or whatever. It just needs a certain minimum level of brightness to read accurately. If you pick a "bright enough" level for your projector -- and as Kal says, 30 IRE is usually good enough -- your meter should be able to read it OK. Below 30, your particular projector might or might not put out enough photons to keep your particular meter happy.
PlasmaPZ80U
| Posted: Wed Jul 22, 2009 1:42 pm Post subject: |
| kal wrote: | Exactly!
If I told people to use 20 IRE in the guide there would likely be some people who'd have issues (those with dim projectors and meters that need a higher level of light to work right).
Kal |
I have a direct-view Plasma TV with a 100 IRE output of 30 ftL. My luminance curve follows the reference 2.22 fairly well (average gamma of 2.16) and is actually at 3.74% vs. the reference 2.81% at 20 IRE.
In my case, is 30 IRE still the better point to focus on or can I get a better result focusing on 20 IRE?
| Posted: Wed Jul 22, 2009 1:48 pm Post subject: |
| PlasmaPZ80U wrote: | | In my case, is 30 IRE still the better point to focus on or can I get a better result focusing on 20 IRE? |
Like I said before it doesn't matter since you'll want to look at the entire curve in the end anyway and then possibly tweak. Just because you can get 100% accurate results at 2 points (20/80 or 30/80) doesn't mean every other point along the graph will be correct. You use two points and get them as close as possible, then graph the whole thing and then tweak/compensate if needed to get the overall line flat if possible. Compromises are usually required. I get into that in my guide (where to compromise).
It makes no difference which you chose in the end since you'll be checking everything else after anyway.
PlasmaPZ80U
| Posted: Wed Jul 22, 2009 5:56 pm Post subject: |
Sorry, what I was really trying to ask is can I trust my i1d2's readings at 20 IRE (given the conditions described in my last post)?
| Posted: Wed Jul 22, 2009 6:47 pm Post subject: |
Given that you're at 3.74% vs. the reference 2.81% at 20 IRE you are probably getting reasonable readings. Though I would trust my eye more for everything under 30 IRE. Don't worry about below 30. Get everything above as flat as possible using the meter and then use your eyes for below. Measure it if you want for sake of curiosity but don't trust it 100%.
If you want to trust it more, use a Chroma 5.
