cbx_smtp
| Posted: Mon Jul 20, 2009 9:30 pm Post subject: Powerstrip - unable to adjust sync |
Hello all,
As I was finally able to run in 1080i with an old pc, it was time to connect my Barco 701S to my main pc.
I have added an extra VGA card (details below) because I already used 2 TFT screens.
Now I have the problem that I can not adjust the sync settings (see screenshot):
The computers hardware configuration:
Gigabyte X48T-DQ6 motherboard, Intel wolfdale 8400 CPU, 4GB DDR3.
Primary video card: Geforce 9800GTS with standard 2 DVI connectors.
Primary DVI connected to my 26" samsung TFT, secundary connected using a DVI->VGA converter to the PJ.
"newly" added card: Geforce 9600, DVI connected to my 24" Samsung, VGA not connected.
Strange thing is that in Powerstrip I can only adjust the sync settings from my primary VGA card, the other one simply does not show.
This is not a big deal, because I have connected the PJ to the primary card anyway.
When I choose monitor 1 (Samsung), I am able to adjust the sync settings... when I choose monitor 2 (PJ) not.
And that's the problem. I need to select "-" in both horizontal and vertical.
Any suggestions?
Thanks !
