cbx_smtp
| Posted: Sat Jul 18, 2009 9:33 pm Post subject: Barco 701S -> Complete N00B question regarding resolution |
Hello all,
Since you helped me out with my previous (stupid) question, I hope you can help me again.
I recently bought a Barco 701S and also got a Magic Barco Interface for free along with it.
I have connected the Barco using the s-video connector to my dvd player and xbox (not the 360, but the old one) and this works fine.
However, because the resolution is only 768 x 546 (correct me if I'm wrong), the image is not as nice as it could / should be.
When I connect a pc to the Barco using the Magic Barco Interface I am able to get to 1024 x 768 max.
Any higher and the Barco says "input no longer available".
When i read this forum I see resolutions used with this beamer up to 1080i (1920 x 1080) - which means I can use my pc to upscale dvd's ... ?
How can I achieve this resolution? I have a bunch of cables etc... I simply do not know how to use them I guess
Thanks again,
Sven aka N00B
ps. No money to buy a fancy up-scaling device or something ...
Edit... Just found out that if I choose source 93 I can go up to 1280 x 768
I don't even know that these "sources" mean... because when I select source 3 it says "input no longer available".
josh31p
| Posted: Sat Jul 18, 2009 10:36 pm Post subject: |
To achieve 1080i you will need to use a software called Powerstrip and select a 10801 resolution. Remember to select negative sync (which means removing the positive sync ticks). Your results will vary depending on your operating system and graphics card. Some cards don't support 1080i.
cbx_smtp
| Posted: Sun Jul 19, 2009 12:07 pm Post subject: |
| josh31p wrote: | Hi,
To achieve 1080i you will need to use a software called Powerstrip and select a 10801 resolution. Remember to select negative sync (which means removing the positive sync ticks). Your results will vary depending on your operating system and graphics card. Some cards don't support 1080i. |
Hi there,
Thanks for your reply !
In what way should I connect my pc to the PJ?
Do I use the magik interface or not? And do I need to change any of the setting?
Also I an wonrdering what input nr. I have to choose....
Thanks again
Sven.
josh31p
| Posted: Sun Jul 19, 2009 12:31 pm Post subject: |
Hi
I would use a straight vga to bnc cable and connect it directly to the projector, i'm not sure about the input number. Powerstrip is freeware so just download it and give it a try.
Josh
cbx_smtp
| Posted: Sun Jul 19, 2009 1:02 pm Post subject: |
| josh31p wrote: | Hi
Josh |
Last question for now...
As I will buy a ney vga to bnc cable, do I need to buy one with 3, 4, or 5 connectors? (for sync etc?)
josh31p
| Posted: Sun Jul 19, 2009 1:37 pm Post subject: |
I have only used a 5 bnc lead with the two syncs joined together using a T connecter (as there is only one sync input). You might be able to get a 4 connector bnc lead (with the syncs already joined), I have never tried so I dont know.
Just to recap you should have:
red
green
blue
Vsync + Hsync
cbx_smtp
| Posted: Sun Jul 19, 2009 1:51 pm Post subject: |
| josh31p wrote: | I have only used a 5 bnc lead with the two syncs joined together using a T connecter (as there is only one sync input). You might be able to get a 4 connector bnc lead (with the syncs already joined), I have never tried so I dont know.
red
green
blue
Vsync + Hsync |
Wow.. I did not know that ! ...
So.. the red goes to red.. blue to blue, green to green... and the other 2 cables go in which conntector in the PJ?? (joind to one) ... ?
Haha, I'm such a noob
josh31p
| Posted: Sun Jul 19, 2009 2:41 pm Post subject: |
Hi
the two syncs go into the sync connector (the one marked S).
cbx_smtp
| Posted: Sun Jul 19, 2009 2:45 pm Post subject: |
| josh31p wrote: | Hi
the two syncs go into the sync connector (the one marked S). |
Ok, I'm gonna give it a try tonight.
cbx_smtp
| Posted: Mon Jul 20, 2009 12:31 am Post subject: |
It works
Now running on 1080i with my Barco 701S Data.
Using powerstrip and the correct cables / connectors !
josh31p
| Posted: Mon Jul 20, 2009 12:55 am Post subject: |
Glad to hear it. Enjoy !
joatmon
Joined: 17 Mar 2009 Posts: 127 Location: Ottawa, Ontario
| Posted: Mon Jul 20, 2009 4:04 pm Post subject: |
We need the obligatory screen shot now....
_________________ Entertained by a Runco DTV-940 (aka Barco Cine7/708)
