| Posted: Mon Jul 06, 2009 6:24 pm Post subject: BNC cable end source? |
Hello,
I have been using one of the cheap RGBHV breakout cables for a few years now and it has worked great in the past. Two nights ago the red channel went out and I tracked it down to a bad BNC on the cable end. I cut all the moulded plastic off the connector and macgyvered it back together, it works again but I doubt my liberal application of duck tape and super glue will hold forever.
I'd rather not replace the entire cable as the rest of it is just fine and a new (better) 35' cable is more than I'd like to spend. So I'm looking for a replacement plug, I looked a little but wasn't able to find anything that looked like it was designed for the smaller cable, the outside diameter on this cable is about .097 and it looks like the connectors I found were for larger cable.
Anyone have a source?
