moby
| Posted: Fri Jul 03, 2009 6:38 pm Post subject: whats happening with my marquee?? |
Hey guys!
I own a a marquee 9500 lc ultra. And its has been working flawlessly for a year or so. Today when i turned on my crt it started messing up. The only thing that turned on was the red tube and only for about 5 seconds, until the picture turns black and then it start over and over again. what the heck is going on?
_________________ http://www.curtpalme.com/forum/viewtopic.php?p=171911
| Posted: Fri Jul 03, 2009 7:01 pm Post subject: |
Hello
If it comes in and out of focus then you probably have a high voltage arcing problem. It could be the high voltage splitter, and anode cable where it attaches to the tube, if so you would hear a squealing noise. If silent, it is likely the hvps.
| Posted: Fri Jul 03, 2009 7:15 pm Post subject: |
Wow, with all these Marquee problems I'm glad I sold mine, got out, and bought the G70
In all seriousness though I would start by checking the mini rca connectors both on the VIM and on the neckboards, I had cold solder joints on my VIM that caused the same problem, if the focus is drifting I would also check the HV section.
Good luck
moby
| Posted: Fri Jul 03, 2009 7:25 pm Post subject: |
| Tim in Phoenix wrote: | Hello
If it comes in and out of focus then you probably have a high voltage arcing problem. It could be the high voltage splitter, and anode cable where it attaches to the tube, if so you would hear a squealing noise. If silent, it is likely the hvps. |
Well its not making a squelling sound. so it must be the hvps. What do I do to fix the problem?
moby
| Posted: Fri Jul 03, 2009 7:40 pm Post subject: |
| Zebu Fellenz wrote: |
Good luck  |
Hey!
Sorry im not so much into this. Hope you can explain it to me like im a 10 year old What excacly is it that I should check for on the VIM card and neckboard?
| Posted: Fri Jul 03, 2009 8:40 pm Post subject: |
| Zebu Fellenz wrote: | Wow, with all these Marquee problems I'm glad I sold mine, got out, and bought the G70 :wink:Good luck  | Touche, but your day is coming Sony boy
| moby wrote: | | Well its not making a squelling sound. so it must be the hvps. What do I do to fix the problem? | put your on the front half of the side panel, next to the Blue tube/lens. Do you hear a ticking sound, like one of those battery powered BBQ igniters?
| Posted: Fri Jul 03, 2009 10:42 pm Post subject: |
| draganm wrote: | Touche, but your day is coming Sony boy
Trust me, my day has come and gone more time then I'd like to think about. I had a Barco that blew up a whole pile of boards, a Marquee that blew a HVPS and has VIM issues, and I've had the power supply boards in my G70 repaired after an out of the blue failure.
Maybe I need an Ampro...
moby
| Posted: Sat Jul 04, 2009 9:13 am Post subject: |
| draganm wrote: | | Zebu Fellenz wrote: | Wow, with all these Marquee problems I'm glad I sold mine, got out, and bought the G70 :wink:Good luck  | Touche, but your day is coming Sony boy
| moby wrote: | | Well its not making a squelling sound. so it must be the hvps. What do I do to fix the problem? | put your on the front half of the side panel, next to the Blue tube/lens. Do you hear a ticking sound, like one of those battery powered BBQ igniters? |
Yeah i can hear something. What is that?
| Posted: Sat Jul 04, 2009 5:20 pm Post subject: |
| moby wrote: | | Yeah i can hear something. What is that? | it's internal arcing ion the HVPS, not repairable but Curt has plenty of them. Also a good chance to let me upgrade the rest of the machine for better reliability and performance
