Sony Hdmi/Component card Questions, Left Shift and Gamma
bigsilverdisc
Posted: Fri Jul 03, 2009 6:35 am    Post subject: Sony Hdmi/Component card Questions, Left Shift and Gamma
Hi
I have the G70 with the Sony hdmi/Component card.
When watching Pal SD dvd from my Blu or HD DVD player the pic shifts left and i cant shift it back enough is there any way to fix this with this card?
With the Gamma i only notice the picture change with the first press and all that does is turn black to grey or washed out black, is this the way it is supposed to be?
I have adjusted the screw and the yellow light does what it does so it seems to working.
I had a friend bring his Hd Fury connected to the Box 1020 to try.
The 1020 has a control to fix the left shift and that works great but what I find so much better is its BB or Black Boost adjustment, You can really see every fine adjustment you make and it gives so much detail in the black without making the blacks grey,
Is the BB (Black Boost) differant from Gamma or are they the same?
moome
Posted: Mon Jul 06, 2009 11:44 am    Post subject:
hi, can you tell us how much shift for your image? what resolution you use? the gamma control function same as black boost.
