light vertical lines on marquee 9500 ultra, like moire
seanoise
Posted: Tue Jun 16, 2009 7:06 am    Post subject: light vertical lines on marquee 9500 ultra, like moire
hello, i hope somebody can halp me.
ich have light vertical lines on my marquee 9500 ultra, it looks like a moire effect.
it is visible on not-detailed, dark and middle-light picture-contents, and occurs at high resolutions like 1080p@60hz or 1080p@72hz.
at lower resulutions like 720p@60hz or 720p@72hz its not visible.
it is on all three tubes, even on the internal test-patterns.
do you have an idea?
Posted: Tue Jun 16, 2009 6:22 pm    Post subject:
Hello
Help us out with some pictures of the problem.
seanoise
Posted: Wed Jun 17, 2009 8:11 am    Post subject:
hello. good news!
i solved the problem by myself.
the problem was a noise in the connection between the focus-board and the tubes.
i put a ferrit-filter around all three wires, and now the picture is perfect homogen.
maybe someone helps this information...
Posted: Wed Jun 17, 2009 1:37 pm    Post subject:
seanoise wrote:
hello. good news!
Did you put them on the "bunch" of focus cables?
seanoise
Posted: Wed Jun 17, 2009 2:37 pm    Post subject:
yes, i put it around the bunch.
means the focus-wires for all three tubes pass the ferrit-filter.
it has the same effect like three filters, one for each tube.
Posted: Wed Jun 17, 2009 3:58 pm    Post subject:
well ok but there shouldn;'t be any noise in those lines to begin with. Maybe you need to have those boards re-built?
Posted: Wed Jun 17, 2009 4:01 pm    Post subject:
Very interesting, both with the problem and the fix. Can't say I've seen that problem before at all. I'd say leave it for now, but as Dragan says, you might have a problem that will get worse. I'd say the focus board is going bad, maybe the LVPS.
I can't see you damaging anything with your fix, or running it that way for now.
