Focus at Barco 808 with P16. Questions!
Verrückter
Posted: Fri Jun 12, 2009 5:07 pm    Post subject: Focus at Barco 808 with P16. Questions!
Hello,
Unfortunately, I speak bad English. Please excuse.
It is about the Barco 808G one with and one without s. The difference is in the field of electronics, to my knowledge only in two or three boards. Do you know whether I just made the boards 808Gs nem 808G stuck in a can?
Also I have a 808sG in the P16 tubes were built. The Neckboard regarding pinout has been changed. I now feel as if I were the focus coil still have to push forward in order to focus. Unfortunately, you can not, because the deflection of the way. Now I have seen that the R-No. the focus coil of 808G, which is indeed the DMB has tubes, is different than that of the coils of 808Gs. Can you say something about this?
Thanks a lot!
Stefan
PS: Maybe even German-speaking specialists here, then perhaps by PN.
Verrückter
Posted: Fri Jun 12, 2009 5:43 pm    Post subject:
Mh, which R-Nr. have the Focusyokes in the Cine8?
Stefan
r.bauer
Posted: Sat Jun 13, 2009 8:52 am    Post subject:
The partnumber of the green focus coil is different from the red and blue focus coil. Make sure the right coil is mounted on the green tube. Also use the focus coils that came with the chassis.
The BG808 and BG808s chassis' may look very similar, but there are many differences. Most of the boards are new or improved so they can not be swapped between the s and non-s chassis.
You can also PM me in German. Ein Privat nachricht auf Deutsch ist kein Problem für mich.
