Ecp 4000 no external video signal
hungso
Posted: Fri Jun 12, 2009 3:58 pm    Post subject: Ecp 4000 no external video signal
I just hard reset the projector a few days ago trying to redo all the mechanical focusing inorder to reduce the stress on the electronics. I can use the internal video to set up the projector again but lost the external video. I didn't change any external set up. Everything work fine before the hard reset. I switch the input board from a spare board and same situation, only internal video but no external video.
It is an ECP 4000 with firmware version 0.7.
Any help please.
Posted: Fri Jun 12, 2009 4:44 pm    Post subject:
When you do a reset, the 'source' defaults to some setting that most likely is other than yours. I'm sure once you select the proper source (0,0 0,1 1,0 or 1,1), you'll be back to normal.
hungso
Posted: Fri Jun 12, 2009 5:49 pm    Post subject:
Hi Curt, thanks for the response. Before i used to visit the AVForums for the last few years, however, recently there is not much infor. for thoes good old Ehome projectors. Your site seems to be the only resource that still available.
Back to the story, the video input card is at the last slot of the projector, when i press "source", the screen show "slot 1, input 1", when i try other options like press "source", follow by number 1 and 0, there is no change! I will try again tonight when i get home after work.
Thanks.
hungso
Posted: Mon Jun 15, 2009 2:15 pm    Post subject:
Finally i get the external video signal back, the magic number is "slot 1, input 2".
Thanks.
