How do you install a Red C Element 9500 L/C
dturco
Posted: Mon May 11, 2009 10:29 pm    Post subject: How do you install a Red C Element 9500 L/C
I tried to install a red c element. I took off the lense then put the red element on the back side of lens matching the curvature, then tried to put the lens back on. The bolts were to short and the lens would not seat. The c element packaging says hd-10 red element with a 17 on the plastic case. Does it go on like this or some other way?
http://www.hulu.com/firefly
Posted: Mon May 11, 2009 10:34 pm    Post subject:
http://www.curtpalme.com/Changing_C_Elements1.shtm
It's a little more involved, you need to remove the C-element before you can replace it. Wink
dturco
Posted: Mon May 11, 2009 10:42 pm    Post subject:
Thank you. And balls on that I just got it to work. I think I'll watch movies for a while then maybe [slim chance] maybe I'll do that.
Posted: Mon May 11, 2009 10:44 pm    Post subject:
On many 9500s, it's a royal PITA. You risk ripping the bellows if it's stuck too well.
dturco
Posted: Mon May 11, 2009 10:46 pm    Post subject:
Is it really worth it? Especially if your not doing the green too? Edit : never mind I re-read the link 9500's already have green tinted c elements.
Posted: Mon May 11, 2009 10:52 pm    Post subject:
"Ignorance (of proper color) is bliss" Wink Does it look good enough to YOU?
Why would you have to do the green? I thought the Marquee came stock with a filtered green?
Erik
dturco
Posted: Mon May 11, 2009 10:56 pm    Post subject:
Erik
I like to make things hard on myself chasing the best possible "whatever" I am involved in. But not this time Question
Green c element is installed re-read post. Embarassed
Posted: Mon May 11, 2009 11:45 pm    Post subject:
Yes it does make a difference. here is my procedure that gives less chance of ripping the bellows but if you do rip it, no worries we can now get bellows no problem!!
http://www.curtpalme.com/Marquee_LC_removal.shtm
By the Way, where id you get a red C element? And I hope you did not scratch it or the HD 10 lens' when you tried to Jam it between the existing Clear C-Element and the Lens!!!! Shocked Shocked Shocked
dturco
Posted: Tue May 12, 2009 12:04 am    Post subject:
Nashou, No I did not scratch either of them. They actually almost fit with clearance, no forcing at all.
The C element came with the 9500 It was just not installed it was still in an unopened box Surprised
Where has the glycol gone in your procedure?
And one final thing I was thinking about waiting for the new bellows before I even think about doing this.
Whats new on that front?
Posted: Tue May 12, 2009 12:10 am    Post subject:
Glad you did not scratch either!! Wheeeeouuu!!! In the thread i did that procedure there were earlier post's where i used a syringe and some hobby tubing to suck the glycol out the tiny fill holes on the top of the LC housing. it take time to do. The bellows are on the assembly line schedule and i I hope should be done when I get back from my 25 day trip. Hopefully Dragan will have tested the first sample I sent him and let us know how it works. I have no doubt it will be 100% perfection Very Happy
here is the origial post: the first method was the one that can allow the bellow to rip, further in the thread i discovered the newer better method.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=12094.html
Posted: Tue May 12, 2009 12:28 am    Post subject:
You need to stop right now and do some studying. Quite frankly, I'm surprised you have not broken or at least damaged something trying to stuff the red c-element between the lens and old clear element. You are in over your head . This is advanced stuff you are trying to do here. The whole tube assembly should be removed for a c-element change to eliminate the chance of getting glycol into the electronics. In the ten or so years on this and AVS forum, I don't recall anyone ever trying to do what you tried to do. Sorry but that needed to be said.
dturco
Posted: Tue May 12, 2009 12:47 am    Post subject:
I have been admonished. But really there was no contact of any sort, kinda like marquee idiot proofed this part, which I guess I proved huh? Rolling Eyes
Relax it will al work out ohhmm. ohhmmm,ohhmm Laughing
jkruger
Posted: Tue May 12, 2009 1:13 am    Post subject:
OM SHANTI, OM SHANTI, OM SHANTI, NAMASTE!
dturco
Posted: Tue May 12, 2009 1:20 am    Post subject:
Right on Brother Thumbs Up
Mr. Green
Posted: Tue May 12, 2009 1:45 am    Post subject:
I'd agree with your earlier thought. Wait until the bellows are available and do it all at once. I'm personally desperate to find a Red C-element of my own that will go with the new bellows. Compared to my NEC, the red looks orange, not red. Skin tones are where I notice it the most. Still, there is nothing terribly wrong with the colors as they are. I'd say wait and do everything at once.
Glad to hear the beast is working! Thumbs Up
Loving mine right now. Just bought Lego Star Wars and Lego Indianna Jones for it tonght (PS3 version)!
dturco
Posted: Tue May 12, 2009 2:05 am    Post subject:
Alright mr.green Thumbs Up
yep she's up and running. Picture is pretty good now that I have turned up the white balance to 65. is that high? Contrast is at 52 brightness at 55.
I think I need a high gain screen. And a moome card, and a red c element installed, and draganm upgrades, and the lottery. Laughing
Mr. Green
Posted: Tue May 12, 2009 2:20 am    Post subject:
We'll have to let Nash chime in regarding the white balance.
I agree, need upgrading... and a lotto win!
Posted: Tue May 12, 2009 2:29 am    Post subject: Re: How do you install a Red C Element 9500 L/C
dude, than kind of fumbling and bumbling will cause you endless grief. You really need to read a lot more before you do anything inside a CRT.
I'm trying, the tube in that assembly was burnt too and I did not want to put in a new bellow with the old burnt tube. I made a tool today after work to get the old tube out, hopefully it works. Otherwise it's all apart and almost ready for re-assembly.
BTW, trying to save the old bellow is like trying to re-use toilet paper. Throw that sh*t in the trash Laughing
Mr. Green
Posted: Tue May 12, 2009 11:47 pm    Post subject:
That is both funny and disgusting all at once. I thought that's why you pay more for 2 and 3 ply... more uses. Wink
Posted: Wed May 13, 2009 2:10 am    Post subject:
NO that's for traction. So you don't burn through on the rub. Wink
