dturco
| Posted: Fri May 08, 2009 12:49 pm Post subject: What size allen key for Marquee lenses |
What is the size of the allen key for removing lenses from marquee 9500 L/C. GT 17 Lenses build date 1997
5/32 does not fit. 3mm, 4mm, don't fit. It seems to be 3.5mm I can not find one to fit the 1/4 inch driver in this size. I went to Sears, Lowes and home depot.
http://www.hulu.com/firefly
jkruger
| Posted: Fri May 08, 2009 2:00 pm Post subject: |
Sounds like you need a 9/64" or smaller, 1/8"
dturco
| Posted: Fri May 08, 2009 2:05 pm Post subject: |
| jkruger wrote: | | Sounds like you need a 9/64" or smaller, 1/8" |
I'll check. Thank you.
| Posted: Fri May 08, 2009 3:54 pm Post subject: |
it's 9/64ths . Be careful with the 8 screws. 4 remove the lens, the other 4 will dump Glycol in yor machine.
dturco
| Posted: Fri May 08, 2009 4:07 pm Post subject: |
| draganm wrote: | | it's 9/64ths . Be careful with the 8 screws. 4 remove the lens, the other 4 will dump Glycol in yor machine. |
Dump glycol into the machine? You say that in passing as if it will be obvious which one will and which ones won't. Seriously though how can I tell which ones are the right ones to NOT dump the glycol?
Thank you again Draganm
| Posted: Fri May 08, 2009 6:33 pm Post subject: |
Hello
Look closely at the lens mounting flange. The screws you CAN remove are NOT recessed. They are at 2, 4, 8 and 10 o'clock.
| Posted: Fri May 08, 2009 6:48 pm Post subject: |
well if you look closely and still can't tell then stop, do not proceed.
| Posted: Fri May 08, 2009 6:49 pm Post subject: |
Mr. Green
| Posted: Sat May 09, 2009 12:59 am Post subject: |
I almost did the same thing. WHEW! When I noticed 4 didn't matter as far as getting the lenses off I was like WHOA!
dturco
| Posted: Mon May 11, 2009 10:00 pm Post subject: |
| Tim in Phoenix wrote: | Hello
Thank you. I bought the 9/64th allen key took of the lens and got it right.
The internet has been down again since my last post.
dturco
| Posted: Mon May 11, 2009 10:18 pm Post subject: |
| draganm wrote: | | well if you look closely and still can't tell then stop, do not proceed. |
So nice you said it twice.
