bccole23
| Posted: Sun May 03, 2009 5:09 pm Post subject: help electrohome marquee 9500lc |
i have finally manufactured a bracket and got my projector hung up now i need help with wich cables to run for the video should i use the rgbhv that is already on the pj or should i upgrade it to hdmi and is that worth it as far as picture quality goes any help is appreciated
bccole23
| Posted: Sun May 03, 2009 5:10 pm Post subject: |
what are line doublers scalers etc
| Posted: Sun May 03, 2009 6:01 pm Post subject: |
| bccole23 wrote: | | what are line doublers scalers etc |
These are devices to improve picture quality. The video signal from a standard DVD is in a format, or resolution, called 480i. That signal displayed on a 9500 will have gaps between the scan lines that most people will find annoying. A scaler will redraw the image with more scan lines and fill in the gaps with a denser image. There are many good scalers to choose from; one with 1024p output is a good match for your 9500
| Posted: Sun May 03, 2009 6:14 pm Post subject: |
go buy a Blue Ray player, a good one like a Panasonic. Then add a Moome HDMI input card to the expansion slot on the Marquee, it's wroth every penny of the $400.
Run a simple HDMI cable between the 2 and your done. The player will up-scale standard DVD's just fine, no expensive outboard scaler needed.
dturco
| Posted: Sun May 03, 2009 6:20 pm Post subject: |
Blu-Ray all the way. HDMI to Moome card the new version 1.3. I have the same P/J. with a sony bd550 Blu-Ray and it is super clear. But be forewarned once you start with Blu-Ray you'll be rebuying all of those great dvd's you already have.
http://www.hulu.com/firefly
bccole23
| Posted: Sun May 03, 2009 11:13 pm Post subject: |
thank you everyone. i need to go about 65' to the pj from my devices what cables do i use for the hdmi or do i have to buy one that length pre made
bccole23
| Posted: Sun May 03, 2009 11:14 pm Post subject: |
also i tried to set the convergence and the red and gren align great but the blue won't go left anymore an it is about a quarter inch from the green lines what do i do
bccole23
| Posted: Sun May 03, 2009 11:16 pm Post subject: |
i want to use xbox computer direct tv hd and blue ray i have an onkyo reciever with multiple hdmi in and out
Mr. Green
bccole23
| Posted: Mon May 04, 2009 12:59 am Post subject: |
i wont loose anything by going through my onkyo reciever will i
bccole23
| Posted: Mon May 04, 2009 6:29 am Post subject: |
my onkyo reciever is the nr905 i think it does the scaling etc? but it does not have the rgbvh connectors what should i use for the best results
