Power supply rebuild for iMac G5 low impedance or ESR caps?
Posted: Sat May 02, 2009 12:10 am    Post subject: Power supply rebuild for iMac G5 low impedance or ESR caps?
Hi guys this is the second power supply for my iMac and this time I opened her up and found a bunch of swelling caps.
I know most like to use the LOW ESR caps for computers and I also like them. But some sizes Are hard to find , that is not value but physical size as the iMac's power supply is tight. So will low impedance work just as well?
I am not in the mood to look up the definition of each one, just want to know if it makes any difference.
Caps I need
1000uf 10v 8mm dia
1000uf 25v 10mm dia
2200uf 25 v 10mm dia
1000uf 25v 12.5mm dia
3300uf 10v 10mm dia
120uf 10-16v 10mm dia
1200uf 16v 10mm Dia
I usually look on newark but most low ESR's are from farnell and need to add a 20$ handling charge, I could order a kit but the kits i have seen on Jim Warholick's site are not the same as my power supply. most i can find on Mouser and digikey as well. But the main question is will low Impedance work the same as low ESR's?
Posted: Sat May 02, 2009 12:48 am    Post subject:
Yes, you bet, they are the same.
Posted: Sat May 02, 2009 12:52 am    Post subject:
Cool I thought they were at least close, The Google checkout on the Jim Waroholich site wont let me finish so i have to put together the caps from different vendors now since none have all the ones I want in one place Sad
Posted: Sat May 02, 2009 1:22 am    Post subject:
I went will all Nichicon HE series and one Pani FM series.
the nichicons also had longer life up to 10,000 hours on some!! I leave my comp on 24/7 so this will be good.
Posted: Thu May 07, 2009 12:50 am    Post subject:
Good news Power Supply re capped and she fired up. typing on her right now for this post!Smile Thanks Curt for the confirmation of those caps.
Another thing I noticed the Whites are Whiter now!! they were going a bit pink on me before the power supply was acting up ! Thumbs Up
