CanI add a resistor to dim rope lights?
JustGreg
Posted: Wed Apr 29, 2009 6:57 am    Post subject: CanI add a resistor to dim rope lights?
The subject pretty much says it all. I can't find dimmable rope lights locally so thought perhaps one of our electrical/electronic propeller heads could suggest a simple component or circuit to build a fixed output dimmer. I already bought some blue ropelight and messed with a couple resistors (I don't have the values handy) and got it to dim but the resistors got pretty hot. The 'dimmer' will be inside the riser so heat and a fire hazard is obviously a big concern.
Thanks guys!
Greg
Clarence
Posted: Wed Apr 29, 2009 11:47 am    Post subject: Re: CanI add a resistor to dim rope lights?
http://www.affordablequalitylighting.com/docs/indoor/rope/clear/120vstandard/dx150c/index.html
greg_mitch
Posted: Wed Apr 29, 2009 12:58 pm    Post subject:
I thought any rope lights were dimmable as long as they aren't LED. Never had a problem with mine.
Posted: Wed Apr 29, 2009 2:01 pm    Post subject:
A single rectifier should drop the voltage.
JustGreg
Posted: Fri May 01, 2009 9:21 am    Post subject:
Thanks guys. Much appreciated.
I certainly didn't want to burn down the whole sheebang because I was too impatient to order (and wait for) dimmable rope lights. Shocked
Greg
j2sgam
Posted: Fri May 01, 2009 12:11 pm    Post subject:
Mr Mitch above has it right. Have you tried, maybe, a dimmer controlling the receptacle the rope is plugged into? Could be an easy HomeDepot fix...
