Sony VPH-1271 how to factory default the beast ?
MrCRTing
Posted: Tue Apr 21, 2009 10:32 pm    Post subject: Sony VPH-1271 how to factory default the beast ?
Hi
I have a 1271 PJ and I seem to of confused the poor beast, is there a way to fully default everything back to original factory / firmware default settings ?
Reason I ask is that when I now use the Zone adjustment (after entering service man mode) using the arrow keys (up down left and right) to do anything with any colour or even to basically converge / center the red and blue "zone grid" over the green all I get "Not Applicable" yellow text appear, I use the + and - buttons to move the area of adjustment around the grid ok but again when any arrow is pressed on ALL 21 adjutemsts give the same message N/A!
She's really not happy with me, the naggy little b***h. Evil or Very Mad
Status is ON and everything ells is set correctly so I'm not doing anything wrong, arrow keys work when I use RGB size so the remote is fine.
Have made notes on each colour temperature, bias and drive so I don't have to do all of that again.
There are a load of switches on the Y (CPU) board and a little push switch, are these any good to perform a factory default ?
jkruger
Posted: Wed Apr 22, 2009 1:33 pm    Post subject:
I think you have to go thru all the settings and reset them to factory one at a time. I asked the same question a long time ago and never got an answer.
imprez25
Posted: Wed Apr 22, 2009 6:18 pm    Post subject:
I started to post a "Reset everyting to 128" post, but then I re-read your post. I'm not sure what's up with your projector. I heard there was a way to do a "Hard Reset" but I also heard that sometimes the projector forgets how to turn back on. Wink
Delicious2
Posted: Wed Apr 22, 2009 8:04 pm    Post subject:
page 104 of the operate install.pdf section of the service manual hosted here:
http://www.curtpalme.com/docs/Sony1271_Service.zip
