BG808 convergence question
akajester
Posted: Tue Apr 14, 2009 4:02 pm    Post subject: BG808 convergence question
I was told I needed to let my pj warm up properly before I did a final convergence. I thought that the 20 minute standard warmup was enough but after having issues with the convergence "seeming" to be off time and time again... It appears I need to let my pj warm up for at least an hour before convergence is solid.
My question is, does this seem extreme? Would updating the caps in the convergence tray possibly lower this warmup time? I'm pretty sure the screws are tight so the tubes shouldn't be shifting around. The blue/red can be off by as much as 1/4 inch until about 50 minutes into the warmup process.
My biggest gripe with the time is that I don't want to run the pj for an hour to have my htpc menu look nice. 20-30 minutes would be preferred. I'm trying to keep the hours on my pj as low as possible. Smile
Thanks in advance for any assistance!
-akajester
betel
Posted: Tue Apr 14, 2009 4:09 pm    Post subject:
I ran an 808 for several years. Twenty minutes was more than enough time for the convergence to stabilize. I was using an 6 x 8 screen with the convergence only slightly off at start up. Nothing near 1/4" Something must be wrong.
secstate
Posted: Tue Apr 14, 2009 4:16 pm    Post subject:
It could be a number of things. What are the hours on your projector? Some things I have noticed over the years, the temperature of the room can make a big difference. My media room is frequently in the mid-upper 60s in the winter and I notice a lot more convergence drift until complete warmup than in the summer when it is 74+. Also how hard are your pushing the convergence are you in the preferred 80/20 region or outside that? That can make a big difference as well.
Also how is the your physical setup that makes a huge difference. Are all three rasters the same size? I have seen all kinds of convergence issues when they are not approximately the same size.
Posted: Tue Apr 14, 2009 4:19 pm    Post subject:
I just swapped a convergence tray with someone complaining about drifting convergence, and he reported back that it now was rock solid.
akajester
Posted: Tue Apr 14, 2009 4:35 pm    Post subject:
The pj has a little over 5000 hours on it. It's a cool basement, probably 60 degrees or so. The physical setup is pretty close to perfect, at least to my ability. And I believe the rasters are the same size. I'll admit I'm still an amateur when it comes to the physical setup though so I could be wrong. I'll check the convergence values, good point.
I have a spare convergence tray with all working cards. I bet it came from Curt a few years ago. The previous owner thought he had convergence problems too but said the new tray didn't change anything. Would that imply a setup issue or perhaps something else mechanical?
If I run through the convergence after an hour of warmup, the convergence is off when it cools, but is back to being correct after an hour of warmup. If it was a drift problem wouldn't it be off after an hour of warmup?
Thanks!
-akajester
akajester
Posted: Thu Apr 16, 2009 8:28 pm    Post subject:
I was told that I should upgrade the caps on the horiz shift and vert deflection board, and that might help stabilize the raster shifting. I was also told to upgrade the caps on the smps, according to the barco service bulletin here;
http://www.curtpalme.com/docs/Barco_FSB04_SMPU_Capacitor_Upgrade.pdf
Thanks again Kal and Curt!
Noob question, how do I go about picking out an appropriate capacitor that will work in the smps? According to the service bulletin, it says to replace both c104 and c114 100uf 85 caps with 105 caps.
The service manual shows those are identical and supplies the following info;
C EL RA 100M Z 25E2 85
Sorry for the noob questions. I'd like to go back to school for electronics! But I don't want to wait that long to fix my barco. Smile
Thanks!
Posted: Thu Apr 16, 2009 8:34 pm    Post subject:
I always Suggest the Panasonic FC or FM series electrolytic capacitors. Nichon Brand are good too always look for low ESR or High Ripple, and High temp(105º)
akajester
Posted: Thu Apr 16, 2009 9:20 pm    Post subject:
Would this work? I checked out the capacitor and it said 25v on it.
Mouser Part #: 647-UPM1E101MED
Manufacturer Part #: UPM1E101MED
Manufacturer: Nichicon
Description: Low Impedance Aluminum Electrolytic Capacitors - 105 Degree 100uF 25V 105c 6.3x15 20% 2.5LS
Capacitance: 100 uF
Dimensions: 6.3 mm Dia. x 15 mm L
Lead Spacing: 2.5 mm
Operating Temperature Range: - 55 C to + 105 C
Packaging: Bulk
Product: Low Impedance Electrolytic Capacitors
Termination Style: Radial
Tolerance: 20 %
Voltage Rating: 25 Volts
akajester
Posted: Sun Apr 26, 2009 8:04 pm    Post subject:
thanks everyone for the ideas. It looks like I mechanically aimed the tubes without having set to midpoints first. I noticed in my red and blue raster they were down to like 9 or 10 out of 100. I set them both to 50 and reaimed and it looks great! Now when I turn it on it's perfectly aligned after just a few minutes of warmup time. Success! Thanks!
Elaine Benes
Posted: Mon Apr 27, 2009 12:25 am    Post subject:
Thanks very much for taking the time to post this follow up that explained your issues and how you resolved them, it certainly is a dramatic reminder of the importance of the order of execution when setting up a crt projector...I imagine the previous owner had done the same thing...
