akajester
| Posted: Thu Apr 09, 2009 7:38 pm Post subject: Wanted: starter CRT projector |
I looked around and didn't see if this was against the forum rules, but if it shouldn't be here please let me know and I'll kill this thread right away.
I work at a university and a student worker of mine helped me mount my BG808. Since then he's become very interested in Home theatre and especially CRT projectors. He would like to get a projector of his own and would like to bring it on to the next college with him and set it up there. He's obviously on a college budget and can't afford much. We have some older model panasonics here but he's interested in building a htpc and doing 720p. I was curious if anyone out there has something they were going to dispose of that would at least resolve 720p. We live in central wisconsin and he's willing to drive to another state to get it. He was bidding on the "starship" on ebay and missed out on the auction end while he was in class. doh!
Anyways, if this is OT please delete it and let me know, or I can delete it. I didn't think it was suitable for the Buy/Sell forum and I didn't see any rules about freebies. I sure don't want to take away business from Curt. My hope is that he'll stick with it and eventually get a better setup, thus becoming another customer.
Thanks and have a great day!
-akajester
donaldk
| Posted: Thu Apr 09, 2009 7:50 pm Post subject: |
The 101 types are to be given away, Curt wouldn't even bother getting on his roof to dump 'em, but in decent condition they would still make for a nice big screen tv.
| Posted: Thu Apr 09, 2009 8:05 pm Post subject: |
NO worries. I'd get him to check CL or eBay for something local. Put it this way on the 1031s. I did a service call on an old Zenith PRO 851. Made 3 return trips to the guy's house to try and fix it, and last time I was rewarded with a shower of sparks from the HV section. It had arced, nuking several boards, thus the return trips. WIth teh tube wear and fungus, I finally wrote it off, and talked him into taking one of my 1031s for $500 total including the 4+ hours of service call time. Set looked fine in the shop. HE called about 2 months after I sold it, massive fungus in two tubes. No reason why, just luck of the draw. I finally got to checking another 1031 that I told him I'd swap out. I ran it here for 2 days, it was OK, save for a bit of tube wear. All I did is wire in his auto screen trigger into the 12 volt line of the unit.
He called an hour after I left, the set smoked and shut down. NOw I gotta take a third damn set over there to get him running. No idea if hte screen trigger caused the short, or just bad luck.
Bottom line is, there's no point in sending something as old as a 1031, so he may as well look for something local cheap, Get him hooked, upon graduation he can come back to me for something higher end.
Brooklyn
Joined: 17 Sep 2007 Posts: 494 Location: Morgan Hill, CA
akajester
| Posted: Thu Apr 09, 2009 9:31 pm Post subject: |
Wow, can't believe I didn't see this one earlier. It's pretty close, I'll let him know. Thanks!
Kiev Savoie
| Posted: Thu Apr 09, 2009 9:46 pm Post subject: |
And i was considering buying a 1031 as a tube wear saver for my main pj. I hate jobs that go that way curt, i feel for ya.
Elaine Benes
| Posted: Thu Apr 09, 2009 10:41 pm Post subject: |
I'd bet you the tubes in that XG are great, you can see the corner of the blue tube in the picture, there is no telltale brown evident. Not conclusive BY ANY MEANS, but I've personally bought projectors based on similar pictures and been rewarded with good tubes...
Be forewarned if you do get into an NEC. They are NOT easy to set up. They are NOT intuitive to set up, and they do NOT have a "Guided" setup routine like your Barco...but they can make a superb image...
PS: Make absolutely sure you get/ask for the FULL SETUP REMOTE when/if you end up picking up an NEC. You basically can't do a thing without one...
buxexanic Guest
| Posted: Thu Apr 09, 2009 11:38 pm Post subject: |
i'm selling a broken ampro 4000, it runs but the tubes are dead
if interested call me at 503 250 0359
scir16v
| Posted: Fri Apr 10, 2009 12:24 am Post subject: |
| Elaine Benes wrote: | I'd bet you the tubes in that XG are great, you can see the corner of the blue tube in the picture, there is no telltale brown evident. Not conclusive BY ANY MEANS, but I've personally bought projectors based on similar pictures and been rewarded with good tubes...
PS: Make absolutely sure you get/ask for the FULL SETUP REMOTE when/if you end up picking up an NEC. You basically can't do a thing without one... |
Yes, I still haven't even really begun to set my 1350 up yet. Just playing and figuring out how each adjustment affects the convergence. I've had this set for a little over 2 months and haven't been able to watch a movie on it yet.
| Posted: Fri Apr 10, 2009 1:05 am Post subject: |
Watch Craigslist. I got a Runco 900 with a screen and an 800x600 Runco 2.5 doubler for $200. The deals are out there from time to time.
Brooklyn
| Posted: Fri Apr 10, 2009 1:57 am Post subject: |
Don't scare yourself away from a NEC though...the set up might not be easy but it is doable. With a little bit of reading, your friend will be able to do a decent set up. In fact there is an article on this site based on a NEC set up:
http://www.curtpalme.com/CRTSetupGuide.shtm
akajester
| Posted: Fri Apr 10, 2009 2:42 am Post subject: |
Thanks for the info everyone!
Mr. Green
| Posted: Sun Apr 12, 2009 11:21 pm Post subject: |
| scir16v wrote: | | Elaine Benes wrote: | I'd bet you the tubes in that XG are great, you can see the corner of the blue tube in the picture, there is no telltale brown evident. Not conclusive BY ANY MEANS, but I've personally bought projectors based on similar pictures and been rewarded with good tubes...
Yes, I still haven't even really begun to set my 1350 up yet. Just playing and figuring out how each adjustment affects the convergence. I've had this set for a little over 2 months and haven't been able to watch a movie on it yet. |
I think I put 100 hours on my nec in the first 6 months I had it. I had never set up a CRT before and other than the guides on this site and everyone here who helped, it was all up to me. Once you get comfortable with the set, it gets easier and easier to do. I'd set it up, tweak it, set it up again, tweak some more... over and over and over. Now, I'm happy enough with the image an put about 300 hours actually watching it. LOVE it.
Now, that I've gotten as much as I'm likely to, I want to upgrade to a 9" LC unit.
| Posted: Mon Apr 13, 2009 12:28 am Post subject: |
| Mr. Green wrote: |
I think I put 100 hours on my nec in the first 6 months I had it.  |
That's it? I put 2300 hours on my Sony Rookie
Mr. Green
| Posted: Mon Apr 13, 2009 12:43 am Post subject: |
Almost all of that was trying to set the little bugger up.
Well, now that it's hooked up and looking pretty good, we watch it a lot more.
| Posted: Mon Apr 13, 2009 12:52 am Post subject: |
| Mr. Green wrote: | Almost all of that was trying to set the little bugger up.
Well, now that it's hooked up and looking pretty good, we watch it a lot more. |
Yeah me too
j/k after the first 18 hours I was good. Ok maybe redid the setup 8 or 9 times but still watched many movies in between.
greg_mitch
| Posted: Mon Apr 13, 2009 1:11 am Post subject: |
I've got a 1252 sitting in storage in my basement. The wife says it is CHEAP.
greg_mitch
| Posted: Sun Apr 26, 2009 6:22 am Post subject: |
Projector handed off at 1PM central time. At least one, maybe two new CRT'ers.
Thanks for getting us in touch Dale. Dave seems like a good kid.
akajester
| Posted: Sun Apr 26, 2009 12:00 pm Post subject: |
I'm glad it worked out. Dave was really excited about getting a starter set. Thanks again!
davebot
TV/Projector: Barco 808
| Posted: Sun Apr 26, 2009 2:34 pm Post subject: |
Thanks everyone for the info! Major brownie points!
I have it mostly setup in my garage right now! I still need to do some fine tuning this afternoon!
Thanks again!
