IFB-FULLHD SONY HDMI 1.3 CARD QUESTIONS
Frank D
Posted: Thu Apr 09, 2009 4:14 am    Post subject: IFB-FULLHD SONY HDMI 1.3 CARD QUESTIONS
Couple of questions:
1. What is the little black SW button near the center of the face plate for?
2. To ensure that the contrast adjustment pot is at 0.7 v should I turn the adjustment multi-turn pot screw counter-clock wise about 30 turns? Is there a way to check the contrast trim pot setting value?
moome
Posted: Fri Apr 10, 2009 3:09 am    Post subject: Re: IFB-FULLHD SONY HDMI 1.3 CARD QUESTIONS
1.for switch the input between HDMI0 and HDMI1
2.need professional and special kit to calibrate the 0.7V
Frank D
Posted: Fri Apr 10, 2009 4:47 am    Post subject: Re: IFB-FULLHD SONY HDMI 1.3 CARD QUESTIONS
Ok but we want it to be left at 0.7 volts correct?
So to make sure contrast screw is set at 0.7 volts should we turn the contrast screw counter-clockwise about 30 turns?
LexaDstyle
Posted: Sun Apr 12, 2009 3:15 pm    Post subject:
thank you!!
________________
Если назрела ссора с любимой - доставка цветов Москва , это решение проблемы.
moome
Posted: Mon Apr 13, 2009 2:12 pm    Post subject:
please clockwise at least 25turn until hear tiny click noise on the pot. then unclockwise the pot 4 turn~
thanks
WTS
Posted: Mon Apr 13, 2009 6:24 pm    Post subject:
As you adjust the gamma the output level will change. SO it is best to adjust the gamma then go back and check the output level and adjust it back to .7vpp. It does take some going back and forth but you need to do it to ensure you have .7vpp output at 100ire.
Walter
Frank D
Posted: Tue Apr 14, 2009 4:17 am    Post subject:
OK. But how do you ensure .7vpp output on 100 ire?
