robnec
| Posted: Mon Apr 06, 2009 5:13 pm Post subject: Input error in PG6 |
Hello. I am organizing my equipment recently. I bleeded tubes in XG and now I wanted to do the same for my second PG6. I hooked it up after maybe year and a half in the closet. I have a problem with input. No picture and message on screen incompatible input Li8t
or something close to it. Hard to read on tube face. It also shakes with menu. Remote operates the unit with all commands and menu correct. I have replaced already front small input board, system board and wave board with the same numbers boards from other PG. No changes. What else can I replace? OK I know everything but where to start next. Thank you. Robert.
| Posted: Mon Apr 06, 2009 5:34 pm Post subject: |
Sounds like you might simply need to do a signal entry? H and V cables backwards?
robnec
| Posted: Mon Apr 06, 2009 5:41 pm Post subject: |
Hello. With all my respect, I do not think so. I have PGs for years and this is different. What about video card? Robert.
robnec
| Posted: Mon Apr 06, 2009 7:34 pm Post subject: |
Hello. I think that my issues are related to both system boards being bad. I put a different system board from a nec but not from PG6, PGplus and I have a picture. Problem is no commands are correct but it displays a picture. What else can I check or it is time to buy a correct system board. Robert.
robnec
| Posted: Mon Apr 06, 2009 9:36 pm Post subject: |
Hello. I feel like talking to myself After playing with boards I have a picture but it shakes vertically very fast. Menu too. Is it a problem with a deflection board? There is also a possibility that with time all capacitors inside projector are coming to normal values.
What to do next? Robert.
| Posted: Wed Apr 08, 2009 4:52 pm Post subject: |
I get this from time to time on my 6PG even though I have multiple signal entries setup. Yet, if I forcibly select one (not the first one) it works.
