Colored glycol for BD808
Fredrik
Posted: Fri Apr 03, 2009 7:57 pm    Post subject: Colored glycol for BD808
I know of the DIY procedure but can I buy "real" colored glycol or ?
I got some Roscoe filters that I haven't tried yet, but will do that just to see the difference Very Happy
But I bet that I want to do it for real afterwards.
By they way, is it possible to remove, re-install the tubes while it's ceiling mounted.
Haven't done this before so I would guess it's even more difficult than for you guys but would it be doable for a tube-replacement-newbie ?
Posted: Fri Apr 03, 2009 8:07 pm    Post subject:
Just replace the lenses with HD-144 or HD-145 color filtered lenses with the proper adapter panels. You can also use colored glycol from a Sony if it is in good shape.
The HD-8 lenses are not all that good IMO.
Also read this.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=421.html
And this...
https://www.curtpalme.com/forum_archived/viewtopic.php@t=157.html
Posted: Fri Apr 03, 2009 8:23 pm    Post subject:
Forgot to include if you swap to the HD144 or 145's they focus at about 12 inches closer to the screen so you have to move either the projector or screen.
Fredrik
Posted: Fri Apr 03, 2009 10:33 pm    Post subject:
Or bigger picture, unless it can't focus properly Very Happy
But isn't the HD144/145's pretty hard to get a hold on nowdays.
I know you can buy the kit to mount HD144/145, but where do you get the lenses.
