Barco Graphics 1208 convergence problem with blue tube
Kiev Savoie
Posted: Fri Mar 27, 2009 8:14 pm    Post subject: Barco Graphics 1208 convergence problem with blue tube
I was trying to do a pre-setup of my BG1208 for an 80" inch screen before mounting it last weekend and i could not get the blue tube to line up with the green. I ran out of adjustment trying to get it as far to the left as i could but the center was still off by a good two inches or so. I have had this problem before with a Sony D50. Is there a way to manually adjust the tube positions or something?
secstate
Posted: Sat Mar 28, 2009 3:21 pm    Post subject:
There are raster shift pots for blue and red you can adjust but make sure you do so only with the electronic controls set to midpoint. Also I am assuming you have done the mechanical set up correctly to alight blue and red on green? The pots are shown in Curt's tour of either the 808 or 120x series.
