Dwin and HTPC...no input signal.
benareeno
Posted: Thu Mar 26, 2009 7:57 pm    Post subject: Dwin and HTPC...no input signal.
Hmmm....I've owned a Dwin before and it worked fine. I would have been using an HTPC at that time too. This latest Dwin that I got will not show a pic...no input signal is the message.
The projector turns on...remote works...the synch is negative. I can't figure out what the issue is.
I tried 1080i at 71.928Hz, which should work....nothing. 1280x720 at 60Hz....nothing.
Do I have to match the bandwidth selection in the menu with actual bandwidth of the HTPC? I think the menu is showing 35Khz or so. I guess I should try 480i or 1080i/60Hz?
Ben
