lostindiana
Joined: 15 Mar 2008 Posts: 21 Location: Federal Way, WA USA
| Posted: Fri Mar 20, 2009 4:02 pm Post subject: 2SK511 FET replacement |
Hello Everyone,
Just wondering if anyone knows off hand either where I can get a few 2sk511 FETs or if there is an equivalent part out there with a different part number. I am looking to replace the three in my BG 1208/2
Thanks!
| Posted: Fri Mar 20, 2009 4:22 pm Post subject: |
I have NEVER had a FET go bad in a 1208 neckboard. I've never found a sub, the 2SKs are impossible to find at this point.
lostindiana
| Posted: Fri Mar 20, 2009 4:58 pm Post subject: |
Curt,
Thanks for the reply, I think I might just be paranoid, I saw a few images of barco problems and I have seen diagonal lines on my red tube when bringing up the raster. I don't see any visible lines projected so I must be fine.
I will have to take a look again when I get home.
Thanks again.
-Mike
| Posted: Fri Mar 20, 2009 6:00 pm Post subject: |
I have 8 new 2SK511 here if anyone needs them. $15.00 each. Send a PM.
Ile
| Posted: Fri Mar 20, 2009 7:25 pm Post subject: |
1208 won't use those transistors, those are used in 800 models neck card.
1208 is build using two VPA13 video packs, these are still available.
| Posted: Fri Mar 20, 2009 8:23 pm Post subject: |
Yes they were only used in the 800's as far as I know...
lostindiana
| Posted: Fri Mar 20, 2009 8:36 pm Post subject: |
Thanks for the info guys!
