Barco 1209 - Lumagen and HDFury1 for 1080p/72? HELP!
Chris Frost
Posted: Sat Mar 14, 2009 2:24 pm    Post subject: Barco 1209 - Lumagen and HDFury1 for 1080p/72? HELP!
Hi all,
I have a Lumagen HDQ capable of outputting 1080p at 72Hz, and a Barco 1209 which is very happy to display that resolution image as long as it is fed via RGB. So far so good. Where it all goes horribly wrong is with HDMI sources running at 24fps.
48Hz is do-able via a HD Fury but it is flickery. As you all know, 60Hz is juddery. 72Hz would be ideal but the Fury doesn't go that high. So, the big question is what is everyone else using as a HDMI to VGA interface to solve the 1080p/60Hz max of the Fury?
Edit: At the moment an Eisemann DVI input board is over budget, so I'm looking for an interim solution.
Regards
Chris
Posted: Sat Mar 14, 2009 2:54 pm    Post subject:
You can run the HDFury1 at 1080p/72 as long as you don't exceed the 165Mhz DVI single link specification. Can you adjust porch timings on the Lumagen? You may be able to get to 1080p/72 that way.
Also if you are watching alot of 2.35:1 movies you can set up 1920x807/72Hz and be well within the 165Mhz DVI-SL limitation.
Chris Frost
Posted: Sat Mar 14, 2009 6:50 pm    Post subject:
Yeah, I can dial in porch settings on the Lumagen. Have you got any recommendations for the timing settings?
Posted: Sat Mar 14, 2009 7:10 pm    Post subject:
Let me update the thread title, one of the lumagen guys can jump in here.
Posted: Sat Mar 14, 2009 7:37 pm    Post subject:
First off how are you running this in your chain?. The Only VP i know that can do 1080p@72 out of its digital outputs is the Tv-one C2-2xxx series of Processors.
the Lumagen can do 1080p@60 from the digital and from the analog outs it should can do 1080p@72 no problems.
So I asuume from what you wrote in your first post that you have the HDfury at the PJ and running the DVI out to the Fury from the Lumagen. this wont go that high up to 60Hz for 1080pfrom the HDQ's DVI.
I would put the HDFury before the HDQ and input 1080p@24 to the HDQ and then output the rgbhv at 1080p@72 to the Barco. That should work fine.
I am not sure what the Barco likes for sync timing but try large hsync and Hfrn. But try the default first then mess around with them.
Chris Frost
Posted: Sat Mar 14, 2009 7:50 pm    Post subject:
Ah, this could be the problem then. DVI out doesn't go above 60Hz. Got to scrap the idea of Fury at the pj end and go with it before the scaler.
Have connected RGBHV from Lumagen to Port 5 (RGBHV) on 1209. OK, our sources are (don't laugh, please) PS3 and XBox 360 with HD drive.
Tried PS3 in to HD Fury1, then out from Fury on RGBHV in to Lumagen on input 5 on RGBS using T piece to combine H&V syncs. Went through PS3 video set up. 480/576p and 720p OK. 1080i very jittery. 1080p a no go. Made sure Lumagen set to accept RGBS. What am I doing wrong?
Haven't tried XBox 360 yet.
Posted: Sat Mar 14, 2009 8:00 pm    Post subject:
Just curious why are you combining syncs?
Posted: Sat Mar 14, 2009 8:01 pm    Post subject:
Is RGBS what the HDfury outputs? I am not familiar with is, just the HDQ. When in the HDQ set it to accept 1080p@24 then you should be able to select
what type of signal it is 4:2:2 etc. and RGBS. I am not in front of my HDQ so i cant remeber what the input options are. make sure you use the correct one.
Try the HDQ with no source into it or on to the barco, use the internal menu test patterns and see if you can get it to show up on the screen, then turn on the source and tweek it that way.
Aslo i dont have a barco so it might be some set up in that menu also.
Posted: Sat Mar 14, 2009 8:04 pm    Post subject:
yeay I just caught that? Why? Put the HD fury into a DVI input you can set that input to accept analog
in and then output RGBHV to the PJ.
the Fury can be connected to a dvi input that accepts analog right?
Athnaasios
Chris Frost
Posted: Sat Mar 14, 2009 8:22 pm    Post subject:
Hi AnalogRocks,
HD Fury1 outputs RGBHV on 15pin VGA and comes supplied with breakout cable VGA to 5 x BNC. (Fury2 can output either RGBHV or Component, but we've only got a Fury 1)
Lumagen inputs 5 & 6 accept RGBS if selected from the input menu. Lumagen inputs 3 & 4 are DVI-I, and would accept RGBHV if we had a VGA to DVI converter plug, but we don't. Sad Our only way to connect HD Fury to the Lumagen is RGBS (combined syncs) in to input 5 or 6, so that's how it's wired at the moment.
Yassou (sp?) Athanasios,
DVI-I inputs have options to change input type 4:4:4 / 4:2:2 etc but not seeing the same on input 5 & 6 set up. Only choices are RGsB, RGBS, SCART. I'm assuming that 5 & 6 will accept baseband 15kHz through to 72kHz'ish signals via RGBS. Am I barking up the wrong tree?
Posted: Sat Mar 14, 2009 8:32 pm    Post subject:
Thats what the problem is, inputs 1-4 can be RGBHV, you need an adaptor to go from the fury to the DVI so a VGA to DVI-A adaptor.
http://www.buy.com/prod/steren-dvi-a-to-vga-cable-1-x-dvi-a-1-x-hd-15-10ft-black-steren-dvi-a/q/loc/111/90142659.html
Chris Frost
Posted: Sat Mar 14, 2009 8:39 pm    Post subject:
So 5 & 6 won't accept HD resolutions?
Posted: Sat Mar 14, 2009 8:42 pm    Post subject:
They will but you must have the wrong sync set up. not sure what the HDfury does with the syncs, it might only be RGBHV and combining syncs like that wont work. Not 100% sure though. And getting sync on green is a tough one also to try.
Input configurability:
- Inputs 1-4 can be DVI, HDMI 444 or 422 component, RGBHV
- Input 5 can be Component (HD/SD), Scart (uses in7 for CVS) RGBS, RGsB
- Input 6 can be Component (HD/SD), Scart, RGBS, RGsB
Posted: Sun Mar 15, 2009 12:08 am    Post subject:
Just use a computer video card VGA to DVI adaptor. In reverse.
Chris Frost
Posted: Fri Mar 20, 2009 11:25 am    Post subject:
Combining H & V with a T does appear to work.
Fury passes sync. What goes in, comes out.
Have also played around with sync output settings on HDQ and got that running H-V- for all output modes via DVI Smile
Made some good progress thanks to the timing descriptions elsewhere in this forum. Now have the following outputs running nice and stable from Lumagen to Fury1 to 1209:
1080p @ 47.xxHz
1080p @ 59.xxHz
817p @ 71.xxHz
1080p @ 50Hz
Source settings from PS3
HD @ 1080i & 720p
SD @ 576p (we are Region 2 PAL here)
This set up was a lot of work: overcoming the image shift of the Fury, staying within the limits of DVI, getting sources to give correct resolutions, being ultra careful with 1209 set up to avoid any image kinking with Fury in the chain, astigs, focus, maximising raster usage, adjusting syncs to minimise image flicker, etc etc. Add on top of that colour calibrating the projector and grey scaling too....phew! But all worth it in the end. Thumbs Up
Thanks to all here for your help. Very Happy
Regards
Chris
