siropa
| Posted: Fri Mar 13, 2009 4:32 am Post subject: 8500 won't power up |
I normally keep my 8500 unplugged when not using it. So I go to plug it in tonight and instead of hearing the fans and other noises it normally makes, there is just nothing. No lights. No noise. Nothing. I verified there is power at the plug, but have no idea where to go from here. Any suggestions on what to check? Is there some kind of fuse or something else? I got the set from Curt around 4 years ago and has been working great the entire time until tonight.
Bill
Elaine Benes
| Posted: Fri Mar 13, 2009 4:42 am Post subject: Re: 8500 won't power up |
| siropa wrote: | I got the set from Curt around 4 years ago and has been working great the entire time until tonight.
Bill |
Isn't it under warranty ?
Why post here if its under warranty, just shoot Curt an email...
siropa
| Posted: Fri Mar 13, 2009 4:45 am Post subject: |
I didn't figure after 4 years it would be under any kind of warranty.
Elaine Benes
| Posted: Fri Mar 13, 2009 4:55 am Post subject: |
| siropa wrote: | | I didn't figure after 4 years it would be under any kind of warranty. |
You'll have to ask, I know for a long time Curt offered a lifetime warranty, when that changed, I don't know, but shooting him an email won't take but a few seconds...
siropa
| Posted: Fri Mar 13, 2009 5:24 am Post subject: |
thanks. i'll give those a check.
siropa
| Posted: Fri Mar 13, 2009 5:42 am Post subject: |
I opened up the LVPS and found 4 fuses. All 4 tested ok.
| Posted: Fri Mar 13, 2009 10:27 am Post subject: |
| Elaine Benes wrote: | | siropa wrote: | | I didn't figure after 4 years it would be under any kind of warranty. |
You'll have to ask, I know for a long time Curt offered a lifetime warranty, when that changed, I don't know, but shooting him an email won't take but a few seconds... |
"lifetime support" you trouble maker
_________________ Chip
| Posted: Fri Mar 13, 2009 12:24 pm Post subject: |
Ummm no, that was PSI in Wisconsin that did that, and try and get warranty from them now.
WHat I do is put a 90 day warranty on the set, very liberal with that mind you, and 1 year on any new tubes. Tech support is always free, and I give big discounts on repairs/parts for the life of the set.
Check to see if the fans are still spinning on the LVPS. Pop that front metal cover to see if they are on. If not, then there's a big 10 amp fuse in the LVPS, but almost guaranteed it's popped because something fried on the LVPS.
Shoot me an email, I've got lots of LVPS here.
siropa
| Posted: Fri Mar 13, 2009 2:03 pm Post subject: |
i'll check the fans tonight.
No I didn't check for a fuse inside that metal cage. I'll do that as well.
Thanks for the suggestions.
siropa
| Posted: Sat Mar 14, 2009 4:05 am Post subject: |
I checked the fuse in the metal cage. It was fine.
I borrowed a LVPS from a friend and the CRT powered right up. whew
Is the LVPS something that is repairable or just buy a replacement?
| Posted: Sat Mar 14, 2009 4:35 am Post subject: |
Curt can probably repair it. But do a swap with him. I remebr jea Hong lee suggested to look at these parts if you "have problem" with LVPS.
His translated page Look on the left side menu for the 9500LC upgrade, he has some interesting things in there.
here is his comments, not sure exactly what he means by problem but its worth a shot,
| jeah Hong lee wrote: | If you have problem in LVPS , check Q27 trnsitor which is Signetics BUZ80A. You can replace NEC 2SK2139 as very good subsitute.
Also check U18 IC which is UC3844 and 1ohm fusable resistor i circled.
and go on to repalce Q24,26 and ddiode D60 |
